Time Capsule
  • Eastcoaster
    • Jan 2012
    • 508
    • oceancity NJ
    Time Capsule
    I picked up this 125 with less than 100 miles I think it still has the original fuel from 75 I opened the tank it is solid Mud. The engine spins freely
    Looking forward to trying to get it on the road
    82 XJ1100J
    81 Venturer
  • Eastcoaster
    • Jan 2012
    • 508
    • oceancity NJ
    thought I poster in other section
    Ugh thought I posted in other bike section
    My mistake
    82 XJ1100J
    81 Venturer
    • donebysunday
      • Oct 2012
      • 1737
      • New Berlin, Wi.
      GREAT FIND !!!!! Don't let that little pocket rocket catch you off guard, once you hit the power band you need to aim by balance as the front wheel won't steer for you ! FUN FUN FUN !!!!!
      76 XS650 C ROADSTER
      80 XS650 G Special II
      https://ibb.co/album/icbGgF
      80 XS 1100 SG
      81 XS 1100LH/SH DARKHORSE
      https://tinyurl.com/k6nzvtw
      AKA; Don'e, UD, Unca Don'e
      • MarkD
        • Jun 2013
        • 488
        • N. Michigan
        Looking like maybe a '73 or something? Sorta like the days when a bike was a bike. Love these old scoots.
        79 F
        1967 Suzuki X6 Hustler
        1973 Suzuki TM 125
        1979 XS1100 F
        2005 Kaw. Vulcan VN800
        1991 BMW K75
          • 2103
          Noteworthy!
          Can't believe how nice the cosmetics are.
          So glad someone is providing some TLC.
          • Prisoner6
            • Aug 2013
            • 1184
            • Phoenix, AZ
            Nice pick-up, Gordon ...
            Look forward to hearing your progress on getting her road-worthy!
            Marco
            1979 Honda CBX
            2002 Kawasaki ZRX1200R
            WE MISS YOU, DON
            • webbcraft2150
              • Sep 2002
              • 1605
              • AUSTIN.TX
              Step away from the ring a ding. Give me your location and I will rid you of that polluting, gas swilling heartache. don't forget to drain/clean the oil tank. I had a RD200 for a long time. Very narrow power band but a hoot to drive. Nice find.
              • Gmac
                • Aug 2014
                • 256
                • Huntsville, AL.
                Probably a '72
                Check the head tube for the date but most likely it's a '72 because it doesn't have a disc front brake. It also has those huge turn signal lenses, not the much shorter pie type found on '73's and the screw on gas cap.
                See about getting one of the body shops to get rid of that dent without disturbing the paint and you have a really pristine collector's item.
                I've never seen one with that type of luggage rack before.
                79 SF & 80 LG MNS
                73 & 74 RD 350's
                73 Honda CL 450
                Graveyard - '81 XS850 Special
                  • 1948
                  had a buddy back then
                  that had a Kawasaki 750 two stroke. Damn thing was nothing but raw power on two wheels. if you came off the clutch too quick you would be on your backside. The front wheel was hard to keep on the ground. The only problem with these types of bikes is that is all they ever were, raw power, with no balance. I didn't like to ride it because it felt so squirrely. Nice find and I hope you enjoy it.
                    Hmmm......memories of the two-stroke tripples. Both the Mach I (500) and Mach II(750) were a definite adrenaline rush,
                    • donebysunday
                      • Oct 2012
                      • 1737
                      • New Berlin, Wi.
                      You really got us stirred up with that bike ! Bet the head stamp date shows 74 but was sold as a 75. It would be worth the price of paint less dent removal. Nice how that oil in the gas (need to find out if it's set up for synthetic ?), keeps the pipes from rusting inside out ! I had a 75 350RD for a year it was set up for synthetic oil but I ran low in the middle of nowhere and had to buy a good 30wt.. I rode it to where I was headed on that 30wt. and then home about 400 mi. on the slab speed back then was 55mph. if I member right, NO PROBLEM.
                      76 XS650 C ROADSTER
                      80 XS 1100 SG
                      • rdmcguy
                        • Jul 2013
                        • 515
                        • Denver, Colo.
                        Rd 125
                        A fun little bike....No question it is a 1975...grips seat gas cap and graphics tell me that....had one way back then...even had a set of chambers on it..Fun to dart around on....light and nimble....
                        • Eastcoaster
                          • Jan 2012
                          • 508
                          • oceancity NJ
                          Yes its date stamped 1974 sold in 1975 and titled 1975
                          It is kick start only. Oil injection system. 2 carbs.
                          Pulling the tank tomorrow it is solid crud to the top and pulling the oil tank the oil looks like green slime. The lines are hard as a rock and the carbs are frozen. The good news it spins freely. Still has the original battery.
                          82 XJ1100J
                          81 Venturer
                            • 8025
                            It's not very impressive by today's standards. Perhaps it was that rubber frame that was so exciting. 74 hp
                            Specifications
                            Engine: Air-cooled, two-stroke, transverse three-cylinder,
                            Engine capacity: 748 cc (45.65 cubic inches)
                            Bore x Stroke: 71 x 63 mm
                            Compression Ratio: 7.3:1
                            Induction: 3x 30 mm Mikuni carbs
                            Starting and ignition: Kick start battery and coil
                            Max Power: 74 hp (55 kW) @ 6800 rpm
                            Max Torque: 7.9 kg-m @ 6500 rpm
                            Transmission: 5-speed, chain drive.
                            Frame: Double tubular steel cradle
                            Front: Suspension: Telescopic hydraulic forks
                            Rear Suspension: Dual shocks, Swing arm
                            Brakes: Single disc (front) Drum brake (rear)
                            Dry-Weight 205 kg (423 pounds)
                            Fuel Capacity: 17 liters (4.49 gallons)
