82 XJ550 Maxium itty bitty o-ring
  • webbcraft2150
    • Sep 2002
    • 1605
    • AUSTIN.TX
    Been fighting the carbs on my "free" XJ550. I need the tiny mixture screw O-rings. Son-in-law seems to have figured they were not really needed when he did the carbs. If anyone has a part number or source, I would appreciate it.
    • 8904
    If they are anything like the XS Mikuni pilot screw O-rings, the $5 nitrile O-ring kit from Harbor Freight should have them.
    • webbcraft2150
      • Sep 2002
      • 1605
      • AUSTIN.TX
      I got one of those. I will check it out. Hopefully there will be some small enough.
      • jwhughes3
        • 2798
        • Home of the Alamo
        Keoki there are...I have same kit and did exact same thing on the 550.
        John
        '81 XS1100H - "Enterprise"
        • webbcraft2150
          • Sep 2002
          • 1605
          • AUSTIN.TX
          Harbor freight o-ring kit had right size o-rings. Now, where do I find the itty-bitty, 5mm flat washer? Orings no good with out them. Search for Mikuni parts hasn't come up with much.
            ....Suzuki washer part #13291-29900
            Suzuki O-ring part #13295-29900
              • 8904
              Hobby supply store may have somthing in those washers. Maybe electronics supply too.
              • rdmcguy
                • Jul 2013
                • 515
                • Denver, Colo.
                tiny washers
                YZ 450 or WR 250 f model uses the same size
                • webbcraft2150
                  • Sep 2002
                  • 1605
                  • AUSTIN.TX
                  That's them! My next move was to see what other bike used the same parts but you beat me to it. THANKS! I actually found the itty-bitty SS washers at my "real" bolt shop. The OEM ones have a slight bevel to "cup" the o-ring but I don't think is going to be big problem using flat washer. Don't plan on twisting those screws around much.
                    Welcome........the SuzyGS used the same BS34 II series as the 80-XJ Yammies. NA from Yammy, both were still available from Suzy some three yrs. back.
                    • webbcraft2150
                      • Sep 2002
                      • 1605
                      • AUSTIN.TX
                      The saga (and pain) continues. Got right washer and o rings. carefully cleaned and recleaned carbs before assembly. Float levels correct. Installed YCIS eliminator. Fired it up. Dialed in carbs within a couple inches of each other. Idled great, reved up great. Didnt ride it cause battery was toast. Got new battery. Fired it up. #1 pipe cold. Pull plug, have spark. Changed all plugs out to new NGK. Quick compression check showed 120#ish. When you hit about 5k, and full throttle, all cylinders come on board and it runs great. Crap in #1 carb still?
                      • webbcraft2150
                        • Sep 2002
                        • 1605
                        • AUSTIN.TX
                        Solved
                        Pulled carbs. Removed #1 float bowl. Pilot jet fell out with it. Didn't tighten it when I did the carbs. Reassemble, fire her up. All four on station at idle. Suit up and take it out. Ran great, idled great. Life is good!!
