pulse generators for honda VF1000f
  • windysolar1
    • Jun 2010
    • 53
    • United Kingdom
    been looking around the United Kingdom for Manufacturers of replacement pulse generators for my VF1000F interceptor but failed to find someone
    Are there any one in the USA that makes this item
    I think I have a better chance of finding some new ones in America.
    Any suggestions welcomed
    The old ones are the best 9000 miles from new and rising
    got a Honda VF1000f 1984 for the summer in the United Kingdom.Wow its Fast,Too fast for Me
    1982 Xj1100J Maxim US Specfast keeps going
    1984 VF1000F Interceptor UK need repair sticking pro link joint, off the road currently but in a newly built 17ft wooden garage, just got to finish it
    Is that referring to ignition coils? .......if so any of the VF series 3ohm coils are 'plug'n'play'......500.....750......1000. Have ohm meter with you and check across the two connectors for 3ohm resistance before buying. IMO, 2.7ohm would be the cut-off point, and that DOES indicate they would be headed 'south' for longgivity anyways.
    BTW, the VF Honda series coils are a cheap, reliable plug'n'play coil for our Yammy XS bikes too .......bolt right up, plus the benefit of using any 7mm high-temp resistant plug wire of your choice .
    • windysolar1
      • Jun 2010
      • 53
      • United Kingdom
      Pulse generators
      These are what I am looking for below
      These are fitted inside the engine with oil
      pulse first then spark boxes then coils then plugs
      there must be someone that makes them 480 ohms
        Thanks!.......wasn't a wasted day.......I learned something .
        • WMarshy
          • Apr 2009
          • 2402
          • Mexico NY
          Have you considered a used one? There are a few used ones for sale on eBay...
          http://www.ebay.com/itm/111430718140
          '79 XS11 F
          Stock except K&N
          '79 XS11 SF
          Stock, no title.
          '84 Chevy K-10 "Big Blue"
          • windysolar1
            • Jun 2010
            • 53
            • United Kingdom
            pulse generators wanted new parts
            been looking for someone that makes direct replacement parts because there is a huge shortage of vf1000 parts.
            only less than 50 in the UK
            still looking
            • dbeardslee
              • 4385
              • Maineville, OH
              This outfit is showing the whole pulse generator assembly as available. I don't know if they're new or used - CMSNL pulse generator, etc.
