CB100 Project
  • #31
    Originally posted by kevxs View Post
    just working away on my old honda again.
    I got it running good after adjusting the cam 1 tooth on the timing chain.
    I then put a few more covers and things on and tightened some bolts and now I have hardly any spark. I can get a bit of a spark sometimes but it's not like it was. I also notice when I hook up the battery it says 6volts but when i turn the key on it goes down to 2.3v or so.
    My grounds and main fuse seem to be clean so just wondering how I should go about troubleshooting this issue.
    thanks
    ....fairly easy one......replace battery with new one that is initially fully charged using a 1amp charger.
    • #32
      found a bad ground coming off the stator, running good again!
      1979 XS1100SF 37000km
      Green Dyna Coils
      Stainless Brake Lines
      1973 CB100
      kevXS
      • #33
        Glad you found the issue....with a little more visual inspection. Remember too, a bit more inspection of voltage loss AREA applies MOST of time to these ole' XS11's too, run/stop switch,etc..
