CB100 Project
  • kevxs
    • Apr 2009
    • 353
    • toronto
    CB100 Project
    I have a '73 CB100 that I bought 20 years ago and rode around on as a kid. Its been sitting a few years in need of a head gasket so I've finally gotten around to working on it. I've got the engine out and will tear into it soon. I don't want to spend a lot of time doing a full restoration as I don't have much spare time at the moment however now that its all apart and looking filthy, its temping to tear it down all the way to repaint etc. Anyway I've been taking a few pics and I'll post some eventually, but for now whats the best way to get the engine case cleaned up?
    1979 XS1100SF 37000km
    Green Dyna Coils
    Stainless Brake Lines
    1973 CB100
    kevXS
  • jwhughes3
    • 2798
    • Home of the Alamo
    Soda blast it - non damaging to metal and cleans and degreases.
    John
    '81 XS1100H - "Enterprise"
    • kevxs
      • Apr 2009
      • 353
      • toronto
      i dont have a soda blaster unfortunately . . .
      Green Dyna Coils
      1973 CB100
      kevXS
      • kevxs
        • Apr 2009
        • 353
        • toronto
        Manual says to remove that center bolt but when i put a wrench to it the whole engine turns over. Any idea how to revove that bolt?
        Green Dyna Coils
        1973 CB100
        kevXS
        • rdmcguy
          • Jul 2013
          • 515
          • Denver, Colo.
          bolt removal
          If you can put it into gear...wedge something soft between the chain and sprocket.....or something soft ...such as a penny between the clutch hub and the gear on the crank...air impact would also work...may be left hand thread..use caution...
          • kevxs
            • Apr 2009
            • 353
            • toronto
            cam chain tensioner
            Still slowly picking away at my cb100, the cam chain tensioner has some kind of coating on it that has wore off significantly near the top. the metal underneath seems to be fine (no deep grooves in it). I'm temped to just leave it alone as I don't want to tear into this thing/spend any more than necessary, but I just wanted to see if anyone has any opinions on how crucial that coating is. The bike has about 5000 miles on it and will probably only get less than 20 hours of use per year once its back together.
            Green Dyna Coils
            1973 CB100
            kevXS
              • 8074
              Is the coating missing where the chain rides? If so, I would replace it.
              • kevxs
                • Apr 2009
                • 353
                • toronto
                yes its been obviously worn down from the chain
                Green Dyna Coils
                1973 CB100
                kevXS
                  • 8074
                  It's time to replace it!
                    • 4011
                    I have a bookmark for a DIY soda blaster, involving nothing more than tubing, a box of soda, and an air nozzle (connected to compressor). Google it.
                    • James England
                      • 3039
                      • North of England
                      That's how I did the entire engine on my latest project. The good thing about it is that a bit of soda getting into the engine a little, or gearbox or whatever, doesn't matter....once the engine is running and oil circulates, the soda dissolves. Then an oil and filter change and it's out. Of course, if one used grit or sand, that would most certainly not be a good idea!
                      I used only a small compressor... 9.2cfm and a 2.5HP motor. I used two 25kg sacks of sodium bicarbonate for the whole engine but I didn't bother trying to recycle or catch it...I just blasted away in the yard.
                      I actually used domestic salt to blast the camcover because I just ran out of bicarb. It worked fine! I rinsed everything very well afterwards of course.
                      One important thing with soda blasting though...you will definitely need a moisture trap on the airline. I bought a small plastic one that fitted onto the blasting gun itself and then the airline plugged into it. If you try to blast without this trap, as I did at first, you will get a clogged up nozzle in only a few minutes...even less if there is humidity in the outside air. These traps are only cheap but they are a must for soda blasting.......
                      • kevxs
                        • Apr 2009
                        • 353
                        • toronto
                        yeah i figured I should replace it, was just hoping I could get away with leaving it as I now have to buy an impact screwdriver (to get the cover off) a puller tool (to remove the generator) the tensioner and a new cam chain (cause I might as well replace it since I'll have access). Replacing that cheap part will be expensive!
                        Green Dyna Coils
                        1973 CB100
                        kevXS
                          Hi kevxs,
                          Princess Auto can help.
                          View your Price Wrecker Princess Auto online. Find sales, special offers, coupons and more. Valid from Sep 01 to Sep 30
                          Impact driver $14 on the bottom of about page 3 They have a few branches and their web delivery is reasonable.
                          • kevxs
                            • Apr 2009
                            • 353
                            • toronto
                            thanks Phil, I actually drove there last night and bought it. Just saw your post now.
                            Green Dyna Coils
                            1973 CB100
                            kevXS
                            • kevxs
                              • Apr 2009
                              • 353
                              • toronto
                              the tool worked great!
                              Green Dyna Coils
                              1973 CB100
                              kevXS
