850 charging system?
  • daveyg
    • Feb 2009
    • 411
    • Boise, ID
    My friend gets 13.4v at idle, but drops to 12.4v at 1/4-1/2 throttle, and battery dies within a mile of riding. Any suggestions what to fix/replace first?
    BARE BONES CHOPPERS: If it don't make it go faster, you don't need it!
    80 XS1100SG(cafe in progress *slowly)
    Sounds like the regulator/rectifier is bad. Be sure and check all your connectors for good contact also.
      I'm gonna reverse that...............sounds like bad connections causing high resistance, which WILL eventually result in a bad regulator/rectifier if not addressed.
      • daveyg
        • Feb 2009
        • 411
        • Boise, ID
        Awesome! I'll tell him to start with a tube of dielectric grease and just pop apart and reconnect all of the connectors. Or is there a better method?
          That'd be a starting place. I still think that with the voltage dropping as RPMs increase is a regulator that is unable to handle the voltage increase from the alternator.
          Like Brant said it was probably a poor connection that caused the regulator to fail. Give cleaning the connections a try. An emery board or even a pink eraser on a pencil works good for cleaning the spades, If you just be sure the female connectors are tight you should be good.
          That last line sounded kinda sexy didn't it?
            • 4011
            Lmfaooo. Ur silly Greg.
            • CRXSi90
              • Jun 2004
              • 400
              • Madison, Wisconsin
              Would a chemical cleaner be any help? https://www.menards.com/main/mobile/...975-c-9100.htm
              '81 XS11H Venturer - holed up in storage while life happened since 07/08/04
              '81 Kawasaki KE175 enduro - 63 mph of smokey fun, now with collector plates!
