11 carbs on an 850?
  • daveyg
    • Feb 2009
    • 411
    • Boise, ID
    11 carbs on an 850?
    Friend of mine has a 1981 xs850 and wants to upgrade from the crappy Hitachi carbs, he offered to (almost) cover the cost of me getting a set of the Kawasaki KeiHin carbs (which I'm about fed up with the stock 11 carbs anyway) I was just wondering if anybody has seen if 3/4ths of the 11 carb rack fit on the 750/850 bikes, and would this be feasible? (Probably a little bit of jet swapping)
    He wanted to hunt down a set of the 79-and earlier xs750 mikunis, but can't find any, and even considered the triumph speed triple 900 carbs, but the cost (roughly double the cost of what I offered him my 11 carbs for) is causing him to hesitate on that idea. Thoughts?
    BARE BONES CHOPPERS: If it don't make it go faster, you don't need it!
    80 XS1100SG(cafe in progress *slowly)
  • jjz28
    • Apr 2012
    • 1023
    • Beckley, W. Va.
    Usually over on the xs750 triple site, the have several people with sets of carbs.
    77 XS750 2D completely stock
    • daveyg
      • Feb 2009
      • 411
      • Boise, ID
      I need to join another forum like I need another hole in my head. I'll tell my buddy to get off his arse and research it himself.
        • 8923
        Dave, the problem will be the spacing between the carbs. 36mm/42mm/36mm (1+2, 2+3, 3+4) is the spacing for the XS11 carbs. They are 42mm diameter to slip into the carb boots. Probably best off finding the correct XS750 Mikunis, JMHO
        • mxmikie
          • Aug 2008
          • 482
          • Bouse az
          i have a set of 750 carbs out back in the bottom of a box
          • mack
            • 2411
            • Ontario, Canada
            Carbs
            I have a set of carbs off a triple here too. Not sure if they were 750 or 850's. I haven't seen them in a few years but I can send them down if you need spare bodies and rails and stuff to put a good set together.
            mack
            79 XS 1100 SF Special
            HERMES
            original owner
            81 XS 1100 LH MNS
            SPICA
            78 XS 11E
            IOTA
            https://youtu.be/wB5Jfbp6SUc
            https://youtu.be/RaI3WYHSuWA
            Frankford, Ont, Canada
            613-398-6186
            • daveyg
              • Feb 2009
              • 411
              • Boise, ID
              Thanks for the offers guys, I'll let him know that there's a few sets out there still in existence.
