I don't know if it has been mentioned but the carbs on these bikes are very sensitive to impurities in the fuel. The one I had filled the rear cylinder with fuel a couple times. I should have put fuel filters on it the first time I had the carbs apart.
I replaced 1 cracked float and both float valves because of flooding problems. Although the tank looked clean there was just enough rust to send an occasional particle down the fuel lines and that was enough to stick the float valve open...
Geezer
Geezer
