virago 250 continues to run when key is turned off
  • hamjam
    • 1003
    • Toronto ontario Canada
    Bike stars and runs without the switch in the circuit the only things that I can think of is , I replaced the headlight bulb a month or so ,maybe pinched a wire and it has rubbed to the point of exposure of the wire or when I wired in her hard bags ,but the only change to the wiring for them was to undo the bullet connectors and add in longer wires with lamp sockets
    btw
    It is not run on or dieseling
    Seamus ร“ hUrmholtaigh
    Niimi Moozhwaagan
    NOTICE: No trees were destroyed in the sending of this message. We do concede, however, that a significant number of electrons may have been inconvenienced.
    Any connection between your reality and mine is purely coincidental.
    Member of "FOXS-11" (Former Owner of XS-11)
    and SOXS
    2008 Nomad "Deja Buick'
      Yeah, you need to trace the wires to the ignition circuit and find where its pinched or shorted. I think you should call the bike "Christine"!
      • hamjam
        • 1003
        nowhere near as scary as SWMBO
        Niimi Moozhwaagan
        and SOXS
        • Brent
          • 959
          Hotwired
          When you stall the engine out, or whatever else you do to stop it, all the lights stay on as if the switch was turned to on, even when it is off, correct? Headlight, dash lights, neutral light...etc.
          Have you tried having the key switch loose, but connected, start the bike, then disconnect the switch and see if it continues to run. Just thinking this through. If it is not in the switch then the wires the switch connects are shorted out in the harness somewhere.
          Jim ,
          It sounds almost as though The ignitition circuit has been "hot wired". Do you suppose any unauthorized person took it for a ride and made this modification??
          Perhaps 2 wires just rubbed themselves together?,,,?
          Good luck wrenching
          Brent in Ga
          Brent in GA
