A gal asked my son...
    .. to get this little Honda Rebel running again for her. The starter would only go about a half turn and lock up for some reason. One cylinder looks just fine. The other... not so much.
    Anyone got a spare 250 Honda Rebel motor layin' around? lol.
    Ok, this seems to be much more common in a MC engine than I have ever seen in automobiles. What in the world causes the valve head to drop off the shaft like that?
    • petejw
      • 2269
      • sydney australia
      probably over heating/ lean mixture on an air cooled engine.
      pete
      new owner of
      08 gen2 hayabusa
      former owner
      1981 xs1100 RH (aus) (5N5)
      zrx carbs
      18mm float height
      145 main jets
      38 pilots
        .........maybe......more likely way over revved and dropped valve spring keepers and the valve beat its way to the other side of piston............whatever the cause, a mood point at best......would think that model should'nt be too hard to find a replacement.....
          After reading about them some, I guess it's a problem for the valves in them to stick in the valve guides or seals if they sit a bit. WHen they're supposed to retract, they just sit there like idiots and let the pistons run into them. Instead of bending, apparently these valves are a bit more brittle at the stem. I've seen several pics like it of these little motors.
            And let me guess.... when you showed this to her, did she ask 'is that bad?'...
            • Wildkat
              XS Special Gurette
              • Apr 2004
              • 3416
              • Location, Location
              81 SH Something Special
              79 SF MEAUQABEAUXS
              81SH Nor'eas tah (Old Red)
              80 LG Black Magic
              78 E Standard Practice
              James 3:17
              “Alis Volat Propriis”
              Yamaha XS 1100 Classic
              For those on FB
              • petejw
                • 2269
                • sydney australia
                how does the valve collets dislodge in a valve?
                if it was over revved and caused valve bounce
                the valve stays open and then collides with the piston
                after the valve has broken then the collets might drop out,
                but not before hand, but as u say a mute point.
                pete
                new owner of
                08 gen2 hayabusa
                former owner
                zrx carbs
                18mm float height
                145 main jets
                38 pilots
                  Originally posted by Wildkat
                  So... no comments from the only person I've seen do this same thing to an XS11?
                  • Wildkat
                    XS Special Gurette
                    • Apr 2004
                    • 3416
                    Smarta$$
                    But I KNEW it was bad... and I fixed it myself... sooooo... no
                    Did I happen to mention you're a smarta$$?
                    and no... I don't know where you can find another engine for a Rebel. Except another Rebel.
                    Ooooooooohhhhhhh... mine's pretty intelligent too.
                    lol
                    79 SF MEAUQABEAUXS
                    80 LG Black Magic
                    James 3:17
                    For those on FB
                      - - - how does the valve collets dislodge in a valve? - - -
                      Hi Pete,
                      not from the factory, no. But some fumbling amateur may have botched the job the last time the lady asked for help.
                        No, this gal just bought this bike. Previous owners said it fell over in a wind storm and wouldn't start after that.
                        • Wildkat
                          XS Special Gurette
                          • Apr 2004
                          • 3416
                          Must have been one HECK of a storm!
                          lol
                          So what are(is) you (she) going to end up doing with it?
                          79 SF MEAUQABEAUXS
                          80 LG Black Magic
                          James 3:17
                          For those on FB
                            lol
                            Well, you know how this Oklahoma weather can be Kat.
                            • ddragon63
                              • Jan 2012
                              • 1101
                              • Ridgefield, WA
                              Most Valves are 2 pieces. The head is fused to the stem. You wack the head with an aluminum hammer (piston) it will break off the stem. This is why Hi performance Automotive valves are 1 piece stainless. They take a better a$$ kicking before breaking or bending
                              Don
                              old:
                              1989 kawi ex500
                              1996 yzf-r6
                              1999 yzf-r1
                              2001 kawi zx-6r
                              2000 Ducati 748
                              2002 YZF-R1
                              2005 V-Star 1100 Classic
