GL1100 stutters @ 5500 rpm
  • ddragon63
    • Jan 2012
    • 1101
    • Ridgefield, WA
    Hey Fella's,
    I'm working on my buddies 1980 GL1100. it runs great... EXCEPT! when it gets to 5500 it stutters like its running out of gas... It reminds me of the rev limiter of a modern sport bike. it doesn't matter if you roll into it or stab it it starts stuttering @ 5500. it revs fine in neutral but when you ride it it will do this every time in every gear...
    Weak fuel pump? bad coils? I have no experience with these models so if anyone else does help would be greatly appreciated.
    Thanks
    Don
    old:
    1989 kawi ex500
    1996 yzf-r6
    1999 yzf-r1
    2001 kawi zx-6r
    2000 Ducati 748
    2002 YZF-R1
    2005 V-Star 1100 Classic
  • XJfan1
    • Feb 2012
    • 180
    • Huntington,Indiana
    im sitting here wondering if it has a froze vacuum advance. im not sure if that has the vacuum or manual but its a thought.
    1982 xj 1100
    "The Ape"
    http://youtu.be/AiQ8CqclHr4
      Would have to know if YOU know whether carbs are REAL clean internally first. If your sure it's a fuel system issue and not a secondary ignition issue. Alot of options without knowing what has or has not been done. If a fuel issue, not having super clean emulsion tubes may be PART of the cause......only guessing as there is a number of things that could be the cause under load.
      • ddragon63
        • Jan 2012
        • 1101
        • Ridgefield, WA
        have not checked out timing system... I've inlisted the help of my friend SeaFoam into the carbs cuz that was my first thought. so now if I can get some weather to run it (or my a$$ off my XS long enough to ride his bike )
        purrs like a kitten @ 5k down the highway... I'll give the seafoam some time and miles to work and look over the ignition and go from there. Now I know why its in my garage and not his
        Don
        old:
        1989 kawi ex500
        1996 yzf-r6
        1999 yzf-r1
        2001 kawi zx-6r
        2000 Ducati 748
        2002 YZF-R1
        • ddragon63
          • Jan 2012
          • 1101
          • Ridgefield, WA
          Checked timing today. Its fine. took fuel filter off and had no fuel in it. put hose in a can opened petcock. no fuel flow. blew a little compressed air into line TAH-DAH we got fuel flow. Took upper 'fake tank' off and took fuel sending unit out. Pumped tank out. The bottom has some floaters and the pick-up screen is pretty caked. Cleaned as best as I could and put back together. Runs better but still seems to fumble on me every now and then.
          Called my friend and told him he gets to figure out how to get the tank out of the middle of the frame rails to have it cleaned. I'm not doing it. If he had bought a real bike the tank would be above the frame and easily removed
          Don
          old:
          1989 kawi ex500
          1996 yzf-r6
          1999 yzf-r1
          2001 kawi zx-6r
          2000 Ducati 748
          2002 YZF-R1
            That doesn't sound good. The tank on my Honda ST11 in under seat between frame rails and I can remove it quicker than an XS11 tank can be removed, startin' with a twist of the ign. key to unlock and lift seat off.
            • ddragon63
              • Jan 2012
              • 1101
              • Ridgefield, WA
              not so easy on a Goldwing. The sump kicks out into the cross section of the frame. I think the battery box has to come out and then it pushes out the side of the frame. I really don't know. This is the point where I tell my friend... "I tried... Get yourself a repair manual and learn how to work on it!"
              This is what happens when friends let friends buy Honda's!
              Don
              old:
              1989 kawi ex500
              1996 yzf-r6
              1999 yzf-r1
              2001 kawi zx-6r
              2000 Ducati 748
              2002 YZF-R1
                • 8844
                • ddragon63
                  • Jan 2012
                  • 1101
                  • Ridgefield, WA
                  thanks Phil
                  Don
                  old:
                  1989 kawi ex500
                  1996 yzf-r6
                  1999 yzf-r1
                  2001 kawi zx-6r
                  2000 Ducati 748
                  2002 YZF-R1
                    • 8844
                    NP, if you need the whole manual just give a holler.
                    • ddragon63
                      • Jan 2012
                      • 1101
                      • Ridgefield, WA
                      That would be SWEET! you got it in PDF form?
                      Don
                      old:
                      1989 kawi ex500
                      1996 yzf-r6
                      1999 yzf-r1
                      2001 kawi zx-6r
                      2000 Ducati 748
                      2002 YZF-R1
                        • 8844
                        Yes, it's PDF, sending you a PM.
                        • ddragon63
                          • Jan 2012
                          • 1101
                          • Ridgefield, WA
                          Thanks again Phil Now i can print it off and sit in a chair (maybe drink a few pop's) and watch my buddy pull it apart.
                          Don
                          old:
                          1989 kawi ex500
                          1996 yzf-r6
                          1999 yzf-r1
                          2001 kawi zx-6r
                          2000 Ducati 748
                          2002 YZF-R1
