Abuncha Symptoms, whats wrong with my bike?
  • anarchy18
    • Sep 2011
    • 134
    • Germany
    Pretty sure these problems are all related to one thing!
    Honda 82 Sabre V-4 Motor
    1)the delayed throttle response,
    2)rpms dropping back down very slowly
    3)starting to rev very high at idle, just suddenly without me touching anything. sometimes so damn high i gotta hit the kill switch!!!!!! How can it get that dang high all asudden from a low idle without me doing anything and I'm standing 5 feet away?
    4)Then sometimes just turning off without warning, like it doesnt even slow down first, it just turns off!
    5) big bang coming out of exhause sometimes when i try to start it
    6) Runs alot better with the choke on!!!
    7) Bike overheats very quickly to the point of radiator fluid boiling over
    fan comes on alot even in cold weather
    8) popping alot when i blip the throttle
    9) no power
    Things Ive done,
    carbs clean and synced
    compression test was good
    coils are good
    plugs are coming out light tan
    removing inline fuel filter changed nothing
    she idles perfect
    checked for vacuum leaks, found none!
    jets and everything in bike is back to stock settings
    throttle cables and springs have all been checked and are working fine
    gravity fed petcocks working fine
    added fresh fuel
    this is all i can think of right now any ideas?
    '81 Yamama XS1100 5K7 German Model
    What's the difference between erotic and kinky?
    Erotic = using a feather
    Kinky = using the whole chicken
  • cywelchjr
    XS-XJ Super Guru(Deceased)
    • 4450
    • Sacramento, CA
    On most bikes this is usually a symptom of being lean. this will cause the hanging idle and will also cause the idle to go up as it warms up, and lean means HOT so it will run hot as well. The running better with the choke also points in the same direction.
    • petejw
      • 2269
      • sydney australia
      im with cy, sounds like ur running lean
      if u havent got a vac leak, id check ur float levels,
      a lean float level will run an engine hotter than a lean
      jet.
      dont know about the model but if the ignition timing
      is adjustable id check that also.
      pete
      new owner of
      08 gen2 hayabusa
      former owner
      1981 xs1100 RH (aus) (5N5)
      zrx carbs
      18mm float height
      145 main jets
      38 pilots
      • petejw
        • 2269
        • sydney australia
        jat, if its a water cooled bike u havent
        blown the head gasket have u?
        pete
        new owner of
        08 gen2 hayabusa
        former owner
        zrx carbs
        18mm float height
        145 main jets
        38 pilots
        • cywelchjr
          • 4450
          • Sacramento, CA
          I believe the Sabre's are water cooled. I believe they are a 65 deg v4 engine as well IIRC (of course I could be wrong there (about the 65 deg and v4 part, I'm more sure about the water cooled part)).
          • anarchy18
            • Sep 2011
            • 134
            • Germany
            Ya its water cooled and its a v45 750 Sabre. Im thinking im gonna throw in some bigger jets. Blowing a main head gasket i would feel the air pushing out if i put my hand up close to the cylinder head wouldnt I? Everyone told me to not worry about the ignition timing. It is fixed electronically with the pulse generator as a reference. Spark advance timing is very unlikely as a cause I've been told. You can check it tho and I tried and the left side generator cover must be removed when attempting to check timing(with timing light)and oil is flying everywhere? How do I go about checking the timing without that happening?
            • trdriver71
              • 360
              • Edmonton Alberta
              it is possible if you blow a head gasket to be an internal leak only and you could be pressuring up your cooling system with your compression or you could be burning it or the worst possible thing is that it could get in your oil and ruin your engine.
              '79 XS11SF
              • Barnfresh
                • Mar 2009
                • 160
                • Abilene, TX
                Looks like 82 Sabre V-4 uses constant velocity carbs like the XS11... Sure sounds like bad diaphrams... giving it air but slide not sliding. Just guessing.
                When the horse is dead, dismount.
                Bagapotomus - '80G Attempted Rescue, '78 Engine, Vetter Bags and Trunk.
                • petejw
                  • 2269
                  • sydney australia
                  not likely, run the bike upto operating temp,
                  cpl of different ways to check,
                  is there an xsive amount of water blowing out of the exhaust?
                  remove the spark plugs while the engine is hot, crank the engine
                  over, any water coming out of the spark plug holes?
                  while the plugs are out stick a light into the plug hole
                  is any of the pistons shiney or clean looking compared to the others?
                  pete
                  new owner of
                  08 gen2 hayabusa
                  former owner
                  zrx carbs
                  18mm float height
                  145 main jets
                  38 pilots
                  • strom
                    • 1577
                    • Slovenia, EU
                    You missed a vacuum leak... check and re-check the carb boots a few times.
                    • petejw
                      • 2269
                      • sydney australia
                      hi strom,
                      3rd post, 2nd line. :-)
                      pete
                      new owner of
                      08 gen2 hayabusa
                      former owner
                      zrx carbs
                      18mm float height
                      145 main jets
                      38 pilots
                      • anarchy18
                        • Sep 2011
                        • 134
                        • Germany
                        UPDATE: Noticed Anti-Freeze drizzling very slowly out of the side of the cylinder when the bikes running. SO THE HEAD GASKET IS NO GOOD THATS FOR SURE!!! I will fix that and then get back to you guys and tell you if it made a difference!!!!! HOPE EVERYONES HAVING A HAPPY HOLIDAY SEASON
                        • Lonerider62
                          • Nov 2011
                          • 187
                          • Gaylord, MI.
                          If you haven't already done so, I'd be checking my thermostat. The water you see coming out of the cylinder may be an effect of the problem, not the cause. You say everything else looks good, even the plug color and I'd think if anti-freeze was getting into the combustion chamber you would see a change in plug condition.
                          Can't beat the smell of gas & oil
                          • XJfan1
                            • Feb 2012
                            • 180
                            • Huntington,Indiana
                            What drives the water pump could a gear or key be sheared? Was it full of water no antifreeze and froze?
                            1982 xj 1100
                            "The Ape"
                            http://youtu.be/AiQ8CqclHr4
