Honda CX 500
  • Honda CX 500
    Anyone know anything about a Honda cx500? there is one in the local paper for $200 that needs carb and ignition work.
    Shawn
    78 XS1100E "Black Rat"
    78 XS1100E Parts
    www.hotrod1972.com
    Hey Shawn!
    My son has a CX 500. He picked it up about three years ago, also $200. Had 9700 miles on the clock.
    These are nice bikes. Great starter bike. However, they have their little quirks, just like the XS/XJ's.
    One thing they are notorious for is stator problems. Don't run it on a low charged or dead battery. In order to change the stator you have to remove the engine and split the case. NASTY!
    But they are alot of fun to ride. There were two models, the "Custom" and the "Deluxe". Later, Honda named them the "Silver Wing".
    My son has a Clymers manual that he got with his purchase.
    Hope this helps.
    Bob Udy
      Couple notes I picked up along the way...
      Early CX 500 had a problem with water pump leaking. This was fixed on later models and retrofitted to most early bikes. Still you might ask if the water pump has ever been replaced. If not sure, you may want to consider doing this.
      I seriously considered buying a CX 500 several years back, but decided to keep it simple by running air-cooled bikes. By most accounts the CX is a nice little ride.
      Jerry Fields
      '82 XJ 'Sojourn'
      '06 Concours
      My Galleries Page.
      My Blog Page.
        Just a little added information to Jerry's comments:
        To replace the water pump impeller you must perform the same operations as to replace the stator. The water pump is just above the stator. Owners of these bikes recommend changing the impeller at the same time if you are installing a new stator.
        Bob Udy
          if all else fails... just get it and part it out. but still the problem of , I dont have $200 to spare...lol
          Shawn
          78 XS1100E Parts
          www.hotrod1972.com
            the CX500 is out, but I am trying to work a trade with a guy for a CB750 and suzuki 125.. plus a ninja 500 engine...lol
            If he says no... oh well...
            Shawn
            78 XS1100E Parts
            www.hotrod1972.com
              You're probably better off with out the CX500 anyway. The early ones had serious cam chain problems and the later ones had similar problems to a lesser extent. The front ends were too wimpy for the weight of the bike and flexed fiercely.
              If you have to go with an older Honda, I’d recommend the 750F, 900F or 1100F. These were about the best of the line up in the early to mid 1980s.
              Geezer
