PIckup coils??
  • Tropic-al
    • Nov 2009
    • 176
    • Tampa, Florida
    PIckup coils??
    I am still working on the XJ650J and while turning the crankshaft with a wrench on the square nut to adjust valves, I must have hit the bottom magnetic coil (?) and broke it off.
    It is the bottom black plastic square thing that has a magnetic tip through it. It came fastened to a magnetic plate that bolts to the main piece.
    Can that black plastic be glued,epoxied, JB welded, etc. to the metal piece it came installed in?
    Will it work if I can manage to fasten it securely to the little plate?
    Or I am doomed to buy a whole reluctor(?) plate with the 2 of those black coils as I was told you can't buy them separately?
    Any ideas?
    Thanks in advance.
    79 XS1100F.
    TC's fuse box.
    SOFA filter.
    Venture cam chain adjuster.
    Tkat fork brace.
    Progressive fork springs.
    • 8923
    Hey Al, I don't know if you can repair it, but here's a set on Ebay, $20. The 81 and 82 have the same part #, HTH....
    http://cgi.ebay.com/ebaymotors/108-1...Q5fAccessories
    There are a few more if you feel like doing a search.
    • Tropic-al
      • Nov 2009
      • 176
      • Tampa, Florida
      Thanks Phil.
      It's probably worth spending the $20 than fixing it and it not working or going bad later.
      Thanks for the tip.
      79 XS1100F.
      TC's fuse box.
      SOFA filter.
      Tkat fork brace.
