Advise on YCIS please !!
  • Tropic-al
    • Nov 2009
    • 175
    • Tampa, Florida
    I'm helping a friend on a 82 XJ650J. Just had a bad leak from the head and cylinder and needed carb work. Has around 140 compression on all cylinders. Thinking PO had done top end job as there were 2 new cylinder studs. The leak could have been fixed if I had retorqued every nut and started it to check, as they all seemed loose while tearing it down, but I didn't. I removed head and cylinder and have new gaskets.
    My concern is when tryin to synch the carbs later, what to do with the YICS. I have never done it before, as mine is a 79 Standard.
    Does the advertised tool eliminate that system all together or is it just to install while doing the synch and then removing?
    Where can I get one?
    Any help will be deeply appreciated.
    79 XS1100F.
    TC's fuse box.
    SOFA filter.
    Venture cam chain adjuster.
    Tkat fork brace.
    Progressive fork springs.
  • Yahman
    • Mar 2008
    • 779
    • Salem, OR
    Hi Al,
    You can get the YICS Eliminator from me, just follow the link in my sig below. I recommend that you install the tool and leave it there, this eliminates the YICS system and you won't have to deal with it anymore. Just synch it like you would your 79 Standard.
    Larry
    82 XJ1100
    80 XS1100G (Project bike)
    64 Yamaha YA-6
    77 Suzuki TS-185
    • Tropic-al
      • Nov 2009
      • 175
      • Tampa, Florida
      Thanks Yahman.
      Just to ascertain, with your experience, will this tool fit the XJ 650 J ?
      Thanks again.
      79 XS1100F.
      TC's fuse box.
      SOFA filter.
      Tkat fork brace.
      • Yahman
        • Mar 2008
        • 779
        • Salem, OR
        Thanks again.
        Yes it will, it fits all XJ's with the YICS system.
        Thanks,
        Larry
        82 XJ1100
        64 Yamaha YA-6
        77 Suzuki TS-185
        • SFerinTEXAS
          • Jun 2006
          • 877
          Yahman 's tool is an excellent fix for this . But ... if the head is off I would thread and plug those ports. Done , goodbye YICS forever. If the head is not off then then the YICS Eliminator is the only way to go. Just Me. Now Yahman will charge me double if I need one.
          79SF
          XJ11
          78E
          • Tropic-al
            • Nov 2009
            • 175
            • Tampa, Florida
            Thanks again Yahman.
            Thanks,
            Larry
            I will ask my friend if he wants to spend the $$.
            While strongly suggesting it to him !!
            Will let you know.
            79 XS1100F.
            TC's fuse box.
            SOFA filter.
            Tkat fork brace.
            • Tropic-al
              • Nov 2009
              • 175
              • Tampa, Florida
              Appreciate the input Texas.
              Don't think Yahman will treat you that bad.
              You are making a valid point, especially to someone who might not have the money to buy the tool but has the resources to thread and plug the holes.
              79 XS1100F.
              TC's fuse box.
              SOFA filter.
              Tkat fork brace.
                Hey Al,
                There is a thread on here somewhere with pics of the plugs in place on a YICS head. TRBig did this to his head.
                Basically just tapped the holes for whatever next size up is from the port size, and used a pipe cap of the appropriate size. I believe he used some teflon tape or pipe dope to ensure a good seal. Something that will take the heat the head sees.
                • SFerinTEXAS
                  • Jun 2006
                  • 877
                  Just occurred to me that small freeze plugs(oil galley) could be tapped into those ports, maybe followed by JB weld or Hi Temp silicone. Dunno but worth investigation.
                  Disclaimer... Not responsible if it don't work.
                  79SF
                  XJ11
                  78E
                  • Yahman
                    • Mar 2008
                    • 779
                    • Salem, OR
                    It's all cool. If you need it, great! If not, that's OK too.
                    Larry
                    82 XJ1100
                    64 Yamaha YA-6
                    77 Suzuki TS-185
                      HERE is the thread I was thinking of.
