XJ550 float bowl wet set fuel level
  • XS1100 Newbie
    • Jun 2009
    • 1106
    • Battle Ground, Washington
    In doing these carbs, i needed to wet set the float levels. As you can see, there was no nipple to attach the hose to. I knew there had to be something to mend this problem. I had had the same problem on my XS1100. I trucked on over to the hardware store and looked for anything that might be adaptable for this purpose. I came across some small aluminum tube, also copper, and steel, and stainless. Having a float bowl with me, i tried a few sizes. The 9/32(.014) seemed just a little big, but very doable. My first step was to cut four 7/8" pieces with the tubing cutter. It seemed as though it could be pressed into the hole. I found a 6MM bolt and washer about 16MM long, and inserted this as a driver to protect the tubing. This tubing pressed right in with a little help from my ball pien hammer. They were solid, and had an added bonus. In pounding them in, they flared the end just slightly for a ridge for the hose to hold on. I don't believe there will be any problem with them remaining in the carbs, we will just wait and see when i get it going. Thought i would post the pics as well.
    1980 XS1100LG Midnight
    1991 Honda CBR1000F Hurricane
    A cold beer and another one!
  • SFerinTEXAS
    • Jun 2006
    • 876
    Doing a set of 550 carbs now. I use clear vinyl icemaker tubing. 1/4" OD I think. It fits real good inside those bowls. Home Depot. About 3-4 bucks for 20ft
    79SF
    XJ11
    78E
    • petejw
      • 2269
      • sydney australia
      not that it makes to much difference,
      but if u swap float bowls 1 and 3 it might
      make it easier to get to the drain screws.
      pete
      new owner of
      08 gen2 hayabusa
      former owner
      1981 xs1100 RH (aus) (5N5)
      zrx carbs
      18mm float height
      145 main jets
      38 pilots
      • XS1100 Newbie
        • Jun 2009
        • 1106
        DUH, how did i screww that one up?
        • petejw
          • 2269
          • sydney australia
          lol
          im just perdantic(sp)
          pete
          new owner of
          08 gen2 hayabusa
          former owner
          zrx carbs
          18mm float height
          145 main jets
          38 pilots
