TW 200 Head light
  • rickybeaver
    • Sep 2010
    • 25
    TW 200 Head light
    My son has a 98 TW 200 and the head light is gone. Do I have to replace the whole light, or can I replace just the bulb? Thanks:Rick
    1980 XS 1100 replaced the seat and sissy bar from a XS 1100 standard and changed the handle bars. Did not like the original bars at all.No mod at all except for a four into one header.
    • 8922
    It's probably an H4, you can look it up on the parts fiche....
    • Tropic-al
      • Nov 2009
      • 176
      • Tampa, Florida
      Hi Rick.
      The bulb is the only thing you need replaced. It is a H-4, 12volt 35/35w.
      You should not put anything bigger/brighter as your charging system might not be enough.
      79 XS1100F.
      TC's fuse box.
      SOFA filter.
      Venture cam chain adjuster.
      Tkat fork brace.
      Progressive fork springs.
      • Poprock
        • Apr 2005
        • 594
        • Oregon Coast
        That baby is a perfect candidate for a 35 w. Bi-xenon HID kit, if you can find a place to stash the wiring. 3X the light of a H4, same power draw.
        • rickybeaver
          • Sep 2010
          • 25
          Found the bulbs
          Hi,thanks for the info. Found the bulbs in a local auto parts store and are very inexpensive. Thanks:Rick
