xs 400 prob....
  • brcree
    • Mar 2010
    • 388
    • S.C.
    xs 400 prob....
    I have a 81 xs 400 that I'm putting back on the road...( bring-en back to life). My prob is....I removed the sprocket cover from the trans. to clean behind and make sure the gear wasn't toast. I put everything back together just as I took it apart....cable.......put the cover back on now it won't shift.....what did I forget?
    At this time:
    1985 Goldwing Innr.
    1976 cb 750 cafe racer
    2007 vtx 1300
    81 sx 1100 s h
    81 sx 400 special
    Hi,
    you mean it shifted OK before you took the cover off and now it's back on but the shifter shaft won't turn or that it turns but the gears don't shift or that it shifts but the clutch don't work?
    I suspect you forgot to put it back together properly.
    • rpgoerlich
      • Dec 2007
      • 643
      • Katy, Tx
      The clutch adjuster is in that cover isn't it?
      Richard
      • brcree
        • Mar 2010
        • 388
        • S.C.
        clutch
        Hey Fred......I put it back on the way it came off (cover). The only part I did anything with was the cable...and it just went into a clip that was connected to a round item that is spring loaded. When you pull in the clutch handle the cable pulls this item and it moves outward. This unit couples with a rod that's in the engine. I adjusted nothing in this process.
        At this time:
        1985 Goldwing Innr.
        2007 vtx 1300
        81 sx 1100 s h
        81 sx 400 special
          Hi brcree,
          so it shifts OK but the clutch will no longer disengage?
          Betcha the steel ball that sits between the actuator and the pushrod fell out and went pittypat across the floor and under a bench and you never noticed?
          • brcree
            • Mar 2010
            • 388
            • S.C.
            Hay man...no...it doesn't shift at all...the lever moves up and down but wont change gears............I know the ball bearings you speak of.....I'll check them but I don't remember one falling out. There is on on the other end of the shift shaft and one in the round item I spoke of. The shift rod pulls out of the block very easy.
            At this time:
            1985 Goldwing Innr.
            2007 vtx 1300
            81 sx 1100 s h
            81 sx 400 special
              Hi brcree,
              OK then, the clutch works fine but the shifter won't shift gears even though it's shaft turns with the pedal?
              You say "The shift rod pulls out of the block very easy"
              Do you mean the clutch actuating push rod, which should pull out, or the shifter shaft, which should partially rotate but not pull out at all?
              If the shaft that the shift lever clamps onto will pull out of the block it means that the gearshifting mechanism on it's other end has fallen off.
              • brcree
                • Mar 2010
                • 388
                • S.C.
                Sorry, should have mentioned that it was the clutch actuator shaft that pulls out easy. The shaft that the lever is clamped on pulls in and out about 1/2 an inch and will move up and down some but no changing of gears happens.
                At this time:
                1985 Goldwing Innr.
                2007 vtx 1300
                81 sx 1100 s h
                81 sx 400 special
                • cywelchjr
                  XS-XJ Super Guru(Deceased)
                  • 4450
                  • Sacramento, CA
                  I don't recall mine moving that far. That sound like something may have come out of place. Did you try rotating the rear wheel while trying to shift? They will sometimes end up with the gears not lined up and they won't shift, but moving the wheel will let them shift.
                  • brcree
                    • Mar 2010
                    • 388
                    • S.C.
                    clutch
                    Hey Cy......I'll give that a try as well......when I get time I will remove the rt. cover and see if anything has come loose......hope I don't cause another prob removing another cover........
                    At this time:
                    1985 Goldwing Innr.
                    2007 vtx 1300
                    81 sx 1100 s h
                    81 sx 400 special
                    • brcree
                      • Mar 2010
                      • 388
                      • S.C.
                      clutch
                      Hey Rpgoer....nice selection of 11's!
                      At this time:
                      1985 Goldwing Innr.
                      2007 vtx 1300
                      81 sx 1100 s h
                      81 sx 400 special
                      • rpgoerlich
                        • Dec 2007
                        • 643
                        • Katy, Tx
                        Thanks,
                        Did you get that clutch adjusted and working on the XS400?
                        Richard
                        • brcree
                          • Mar 2010
                          • 388
                          • S.C.
                          clutch
                          Hey Rp......not yet...had a wedding to go to today. Will try and see about it tomorrow. I'll let you know what I find.......
                          At this time:
                          1985 Goldwing Innr.
                          2007 vtx 1300
                          81 sx 1100 s h
                          81 sx 400 special
                          • brcree
                            • Mar 2010
                            • 388
                            • S.C.
                            Clutch
                            Hay, its alive and well.....! After a buddy came by and put and eye on it we figured it out. Had to take the rt. side cover off to expose the clutch basket, behind that you could see the arm that has a oblong open slot at one end and is welded to the rod that goes through the block which has the shift lever clamped on it. Well, the slotted end had jumped off the shifter arm where the slot is. It took the two of us to get the parts back in line but it snapped back into shape without removing the basket. I guess as I was tugging on the shift arm to get it off the rod I must have pushed it in to far, the e ring is missing from the rod on the lft side, that keeps it from going in to far.
                            At this time:
                            1985 Goldwing Innr.
                            2007 vtx 1300
                            81 sx 1100 s h
                            81 sx 400 special
