FJ 1200 carb guru's
  • Steptoe
    • 175
    • Thabeban,Bundaberg QLD , Australia
    FJ 1200 carb guru's
    I have a set of 1200 carbs,, have checked measurements and they will fit in the XS,,
    beside the bowl over flow pipe is the main fuel feed line I assume, cast alloy with 2 o/rings,which is a tight fit,
    above that a bit is another "T", made of plastic,1 o/ring and is a very loose fit,
    #1 is the plastic T an original piece,, and is supposed to be that loose or is it the wrong part
    #2 if I'm right, and the cast T is the main fuel feed what part does the plastic T play
    #3 can we fit the carbs to the XS and cap the plastic T{not being sure what it does}
    the XS carbs are leaking air like there's no tomorrow,around the shaft seals and with a spare carb set will be cheaper than any alternative
    shall await any reply of info,
    never ride faster than your gaurdian angel
    can fly
    1981 rh 5N5
    MIDNIGHTSPECIAL
    1188cc
    4 into 1 pipes with a transac muffler,
    as the motorcycling gods intended everything else stock std
    http://s856.photobucket.com/home/steptoexs11
    http://steptoexs11.webs.com/
    http://www.youtube.com/my_videos?feature=mhum
    1982 vf750 sabre
  • FJ111200
    • Oct 2007
    • 317
    • Crewe, Cheshire, UK
    Look on this parts list and scroll down to the carbs. There's two types of FJ carb, one for California and one for the rest of the World. I just picked the 1989 model because that's the one i've got.
    ✓ Official Yamaha parts list ✓ Easy repairs with OEM diagrams ✓ Free access to parts fiches for Yamaha Yamaha FJ1200C 1989 (K) CALIFORNIA
