so i just spent 2 months polishing, painting, disassembling and reassembling then more polishing... but now the starter doesnt turn.... when reassembling the wire harness i found all the right connections (matched plugs and wire color) except 2 one was a blue and i plugged a ligth blue lead to it and one was a single white lead from the engine that i plugged into a black wire with a red stripe... i looked through all my parts and all over the internet for some wiring help and had to guess at these two leads... when i hooked up the battery and sprayed some starting fluid in her she turned right over and ran for 3 seconds... and stalled so i hit the start button and tried to turn her back over and she acted as if the battery was dying slowly turning and then stopped.... so i charged the battery and tried this morning and nothing i tried to bump start her and nothing..... i did notice the oil light comes on when the start button is pushed so.... help please.....
81550 maxim help
Tags: None
That Sky Blue(Sb) runs to the Nuetral Switch, Diode Assmbly, Starting Circuit Cutoff Relay and the Nuetral Light .Richard -
the neutral light works... and the Sb comes from the ignition module and stops what does it plug in to? right now i have it plugged into a blue wire that matches the blue from the taillightComment
