81 XJ750 Seca, someone started to take it apart and couldn't figure out there were 6 more nuts to take off the head and cylinders... probably woulda run had thay not left everything open and loose then parked it in a field. Only thing physically wrong was a bad coil caused by bad plug ends it looked like. Got a bit of water in the cylinders and carbs. So a top end rebuild in progress. Has a beat up 4-1 Kerker. For $150 I couldnt let it pass.
