Hey folks, what causes a bike to die when it is put gear with the clutch still engaged? I succumb to the experts!
Bike dies
If perhaps you meant when the clutch lever is pulled in, then you may need to adjust or replace your clutch cable. If you truly intended that the clutch lever is NOT pulled in and your putting the bike in gear, unless you have the engine revved up pretty hard, it is going to die. If you do revv the engine up on an 11 and slam it into gear, hold on tight!! You is going for a ride!! If your also holding the brakes on tight, then anybodies guess if it will die or burn the clutch or brakes up. My suggestion is, Do not do that!Life is what happens while your planning everything else!
78 XS750Comment
Good Call Rice Ya!! Teach me to go thinking in terms of an XS11 in the "Other Bike" Forum.
78 XS750Comment
Fooled me
Hi tmon,
when most folks say "clutch engaged" they mean it ain't pulled in, that the engine & tranny are connected. That's why I'm so late in realizing that you are putting the tranny in gear with the sidestand down on a bike that has a sidestand safety interlock. What bike BTW?Fred Hill, S'toon
"The Flying Pumpkin"Comment
Hey DGXSER...
Don't forget about us XJ1100 owners... ours has the switch, also...
'79 F "Time Machine"... oh yeah, Baby....
(Sold back to Maximan)
2011 Kaw Concours 14 ABS
"What we have here is a failure to communicate."Comment
