750 Katana carb questions
  • 79XS11F
    • 3563
    • Ottawa, Ont. Canada
    OK . I just rebuilt the carbs for my 1983 750SD Katana. Instruction for carb sync say that #1 & #4 are synced together and #2 & #3 are synced together BUT #1 & #4 are to be 1/2 a ball higher then #2 & #3. This is when using sync sticks that use balls. I have gages so does anyone know what the difference between the 2 pairs should be?
    Also Where the heck do the carb vent hoses go. There's no place on the air box or engine. Is there suppose to be "T"s in the engine valve cover vent to accept the carb vent hoses?
    Rob
    KEEP THE RUBBER SIDE DOWN
    1978 XS1100E Modified
    1978 XS500E
    1979 XS1100F Restored
    1981 Suzuki GS1100
    1983 Suzuki GS750S Katana
    1983 Honda CB900 Custom
  • stevec5000
    • Oct 2002
    • 131
    • Mesa, AZ
    I put Katana 1100 carbs on my XS1100 and the vent hoses had to go to the air box, the filter or somewhere else with quiet air since turbulence or vacuum or pressure will mess up the float level. Also, the carbs should all be synced the same.
    72 TS185
    77 XS750
    78 SR500
    80 XS850
    80 XS1100 Midnight Special
    81 Seca XJ750RH
    • GNEPIG
      • Apr 2005
      • 1657
      • fl
      If I can remember correctly, the vent hoses just hang loose- with no vacuum on them. A far as the sync, just set them all together and see how she idles. If she idles rough, adjust the 1 and 4s a little higher.
