Kawasaki question
  • Ljay40
    • Jun 2006
    • 149
    Kawasaki question
    Hope I dont get in trouble posting in here Feel free to move it
    moderators if need be
    anyhow
    any kawi gurus out there that may be able
    to tell me if the carbs off 1982 KZ440
    will fit/run a 1980 KZ440
    or point me to a place where someone does know
    thanks In advance
    LjaY
  • nate
    • Sep 2006
    • 116
    • PA
    Im not sure but some one here might.
    1980 XS1100g
    • ZXDavid
      • Jan 2007
      • 116
      • Tyler,Texas
      I think they are the same. Call a dealer and check part #s.
      1993 ZX11D
      1979 CBX
      1973 Z1
      2001 ZX12R
      • prometheus578
        XS-XJ Super Guru (RESIGNED)
        • Aug 2004
        • 4012
        • Olympia , Wa.
        "Oh, like I've got nothing better to do...!"
        Ok...
        I'll run the numbers, check jet sizes and such, see what I can find.
        • pggg
          • 1609
          • NZ
          Don't worry, they'll fit
          • prometheus578
            • Aug 2004
            • 4012
            • Olympia , Wa.
            'Yeah, they'll fit."
            Keihin CV36
            Watch the jetting, though.
            80-83 440-A:LTD series....Two different carb styles, US and Canada.(difference, Unknown.)
            Also...
            Main jet #88 US/ 85 Canada.
            Main jet (primary) 62 US/70 Canada.
            Pilot jet #35
            ______________________________
            80-81 -B series
            Main jet #90
            Main jet (primary) #68
            Pilot jet #35
            KZ440-G1 1982
            Main Jet #70 Canada (US unknown?)
            Main Jet (primary) #65
            Pilot Jet #35
            Put the carbs on.. use your old jetting.
            • Ljay40
              • Jun 2006
              • 149
              Hey You guys ROCK!!
              Thank you very much for all replys I've spent 2 days trying all kinds of websites searching for a answer still aint no further ahead and guess what It was here all the time!!
              Thanks Prom for doing some homework for me!
              your a good guy, dont matter what T.C. says about ya
              • prometheus578
                • Aug 2004
                • 4012
                • Olympia , Wa.
                Awww.... Who listens to T.C. anyway.
                  • 2060
                  Ljay40- My first bike was a KZ 400.Just make sure that the carbs dont leak gas.There are small holes to vent the area below and gas if it is leaking will get into the oil and wreck havoc! I found out the hard way!
                  • Ljay40
                    • Jun 2006
                    • 149
                    Oldyam80SG
                    are you refering to vents in the floats bowls,or somewere else
                    Im not familar with these carbs only been in there once
                    these carbs do leak out of #1 over flow tube
                    Im almost sure the float is shot someone has bent it up pretty
                    good.
                    thanks for the heads up
                    appreciate it !
                      • 2060
                      Below the carbs where the engine oil is- gas leaking out of the carbs for whatever reason will drip into these small holes.They will get into the oil .Watch out Very costly repair.
                      • desert1
                        • 750
                        • Grand Desert, Nova Scotia, Can.
                        Oldkawman
                        Check under "Oldkawman" for Kawasaki parts new and used....
                        Bruce
                        Had a 71 Kawi 500 years ago and even older 250 Kawi Samurai
                        Bruce Doucette
                        Phone #1 902 827 3217
                        • The Lorax
                          • Jun 2005
                          • 1048
                          • Riverside, OH
                          I still have and old kz400, if I remember correctly, those little nipples on the bottom of the bowls had hoses on them so that overflow could be routed harmlessly onto the ground. oh yea, the carbs should fit, it's a parrallel twin, I don't think the overall dimensions in the heads changed much as far back as the early middle '70s. also you can check out kzrider.com or kz400.com, they're fairly informative sites. (no where near as good as this site but...) the kz400.com has it's forum broken up into about a thousand sub forums. broken down by engine size, and topic (chassis, engine, mods, etc.) that old parrallel twin is a pretty good little powerplant. get around pretty good, good on gas, nice little commuter bikes. oh well, it seems I've gone droning on again and written another book. hope I didn't get too far off topic. have a nice day and ride safe.
                          '77 KZ400s (La Putana)
                          • kawa bob
                            • Nov 2006
                            • 28
                            Ha!! I get to respond to a question, you can go to one of our carb experts, wiredgeorge, type it in google and it will bring up his site.
                            he is the carb guy of all times.
