Chain drive (continued)
  • audijunky
    • Apr 2006
    • 707
    • VA
    Figured I would start a new one since the other onewas so long. Here are some new pics from this weekend
    [IMG]
    http://sfranklin8.photosite.com/~pho...7323003810.jpg[/IMG]
    And that all for now folks, Hope ya like it as much as I do!
    Sorry they are so big, I dont know how to make them smaller
    79 XS1100 modified standard
    straight pipe 4-2 exhaust
    Owned 83 Honda V65 Magna
    Owned 02 Vstar 650 classic
    owned 85 Honda Shadow VT 700C
  • xschop
    • Feb 2006
    • 1794
    • oklahoma city
    fat tire
    That's a very cool looking bike....good job, how is the gearing? street vs. hiway?
    MDRNF
    79F.....Not Stock
    • audijunky
      • Apr 2006
      • 707
      • VA
      Thanks you should see it in person.
      I think it is absolutely awesome . It rides so much smoother than before. I think the Busa rear shock is a good fit. It will look even better when I get the front rim switched out, get a rear fender and brake. That is about all I HAVE left to do . I still need to tweak on the carbs some. Good ole low rpm issues.
      How is your bike coming along?
      • audijunky
        • Apr 2006
        • 707
        • VA
        And to think, this is how it started in my life
        • xschop
          • Feb 2006
          • 1794
          • oklahoma city
          coming along
          the weather finally broke here and I finished all the other welding tidbids on it from the sv650 taillight bracket and the Vegas tank front tree mounts....I will be doing Fiberglass fender and sidecovers next weekend....progress of love....You'll never be finished
          MDRNF
          79F.....Not Stock
          • audijunky
            • Apr 2006
            • 707
            • VA
            I hear ya
            • pggg
              • 1609
              • NZ
              Good one Audi, wow that's one looong swingarm, no worries with unexpected wheelies Just curious, what make/model bike is the back wheel actually off, and what diameter disc does it take? Any ideas on what caliper to go with?
              • audijunky
                • Apr 2006
                • 707
                • VA
                The wheel is for harleys 1984-99. it is 16x5.5 inches. No idea right now what caliper I am gonna use or what disc. I was wanting to try and reuse the rear caliper, but can not find a disc with five holes the right diameter(match existing disk) So right now I dont know. Any ideas would be great on that though
                • Trikerneil
                  • Dec 2005
                  • 141
                  • Wareham, Dorset, UK
                  I like that a lot!
                  Neil
                  Triking - it's a way of life!
                  www.trikenest.co.uk
                  • audijunky
                    • Apr 2006
                    • 707
                    • VA
                    Thank you my triker friend, I do too
                    But what a PITA it was
                    • audijunky
                      • Apr 2006
                      • 707
                      • VA
                      Well Pggg,
                      I just bought a rotor off ebay for the rear. it is 11.5 inch and specs on the xs says 11.8. So not much difference. I want my caliper to be under the swingarm, the way yours is. Problem with using the xs caliper mount or any other Japanese bike is my rear axle is 3/4" which is a little smaller than the XS and hard to match to foreign caliper mounts, and the harley mounts all go on top of the swing arm.
                      Do you think it would be a problem if there is a little play between the axle and the hole it goes through on the caliper mount.? In order to use the XS caliper I would have to use the mount as well.
                      Maybe I could get some of that thin shim metal and wrap it around the axle to get a snug fit with the caliper mount?
                      Any Ideas?
                      • pggg
                        • 1609
                        • NZ
                        Yeah for the caliper and caliper bracket, the original harley setup would be the easiest way for sure, but if your harley axle is 18mm? and the XS bracket fits 20mm axles, a strip of 1mm thick galvanised tin or similar, first folded and shaped round the axle then inserted as a spacer will work fine with the XS bracket. I've done that same trick before with bearings etc..
                        Means if using the XS caliper and bracket, there'd be around 7.6mm of unused area on the harley disc. Wouldn't affect braking performance. Now, to use a common underslung japanese twin opposed piston caliper(the pistons float on them, not the caliper) you'd probably be looking at rigging your own bracket because MOST japanese underslung calipers brackets are sized for 220 - 250mm discs.
                        Doesn't mean there's not underslung brackets that'll fit a 290mm or over disc, as there's sure to be cruiser type japanese bikes that run a large rear disc. A matter of finding what models do. I know 50gary rigged his own bracket from a chunk of alloy to fit a bandit underslung caliper to his XS 298mm disc.
                        My setup is a bit of an oddball one, with a GPX750 240mm disc on a ZX6R wheel with a ZXR750 caliper&bracket Good luck!
                        • audijunky
                          • Apr 2006
                          • 707
                          • VA
                          Fiberglassin
                          Hey Chop, how are you gonna go about making that fiberglass fender(s)? I am trying to figure out the best way to do it without a mold.
                          • xschop
                            • Feb 2006
                            • 1794
                            • oklahoma city
                            FG in'
                            I am going to spray foam it and carve it to blend everything in then use clay to get it perfectly smooth and hard to lay the first layer of glass....this will be a process...but results are XSLNT...
                            MDRNF
                            79F.....Not Stock
                            • audijunky
                              • Apr 2006
                              • 707
                              • VA
                              you gonna spray foam the tire?
