82 Maxim 550 Starter clutch stuck........Engaged
  • switz1
    • Feb 2007
    • 70
    • Bushnell, IL.
    My newest a $50.00 Maxim 550 has a few issues, lookin fer help.Bike came with no clutch, taken care of, gummed up carbs removed and cleaned.Starts great sounds good cept for the damn starter clutch stays engaged and winds my starter out.Short of splitten cases and replacing starter clutch any shortcuts?
    1978 1100E Standard
    2 1985 700 Maxim's (black & red)
    1986 600 Radian (basket case)
    1979? GS1000 (no title)
    1980 1100SG Special
  • midnight1980
    • Mar 2007
    • 312
    • cedar city, utah
    Re: Starter clutch stuck........Engaged
    [i]starter clutch stays engaged and winds my starter out [/B]
    i cant see a short cut..
    why dont yah just replace the starter
      Hey Midnight,
      The starter clutch isn't part of the starter motor like in a car, it's a separate mechanism down inside the engine case. There are 3 pinch rollers that slide into position and grab the starter shaft and spin the engine. Once the engine is running, those rollers are supposed to retract back and allow that shaft to spin, but apparently what switz1 has said is that his starter keeps spinning once the engine gets going. After reviewing the parts fiche, I could see that there are 2 idler gears that mate with the starter gear.
      Switz, you may want to check to make sure the starter solenoid is not staying energized. Also, pull the starter motor, and then turn the crank by hand and see if those idler gears are still spinning vs. being able to spin/hold still??
      But like you said, IF it's locked around the starter shaft, then you'll probably have to split the cases to repair it!? Good Luck!
      • switz1
        • Feb 2007
        • 70
        • Bushnell, IL.
        I have tried a different starter and solenoid with no luck.Was really hoping to get this worked out. I might just have to perform surgery. thanks for the replies.
        1978 1100E Standard
        1980 1100SG Special
