81 XS400 SH battery not holding a charge
  • Juelze
    • 4
    • Green Bay, WI
    Hi there,
    I'm having problems with my XS 400sh holding a charge. It will run for awhile and then the battery just dies and it's a brand new battery.
    I had the voltage regulator checked out and was told it's working (12 volts in, 14.4 out). I checked the rectifier and checked all 6 diodes.
    At idle I'm getting 12.25 volts at the battery (idling at 1200 rpm). At 4 grand I get 12.4 volts.
    Also, the carbs seemed a bit messed up or at least the air fuel adjustment screws. When I got the bike it had 1 screw 2.5 turns out, the other was out 5 turns. I cleaned all jets and readjusted the float and backed out the air adjustment screws 1.5 turns. She still seems a bit cold-blooded and takes 10-15 minutes of warming up to idle correctly. Is that normal?
    Any advice is greatly appreciated!
  • HobbyMan
    MeatHead Idiot "GURU"
    • 1801
    • Colleyville, TX
    Check for corrosion on the battery terminals, loose wires, and any electrical shorts
    Acta Non Verba
    • GNEPIG
      • Apr 2005
      • 1657
      • fl
      .. wow, we get this same question about this same bike here alot.
      let me quess, your bike has about 12 to 14 thousand miles on it. i wonder what could be the problem with these? they are such groovy little bikes.
      • Yamaniac
        • Jul 2005
        • 262
        • Stilwell, KS
        ditto what hobbyman said, and check your grounds for corrosion and/or being loose.
        oh, and check the stator first. if you read some of the old threads in here, most people with the 400's have electrical issues.
        Yamaniac
        '79 xs11 sf - WidowMaker, 750 final drive
        '80 xs1100 sg- ENEMY#1 parts bike no title(free)
        '79 f- frame and swingarm (and title)
        '82 yz 490- needs a cylinder, head, & new piston, etc. Got one for sale?
        '88 Honda cbr600- Running, finally! Training bike for swmbo, maybe a stunt bike for me eventually.
        • dwain61
          • Jun 2006
          • 58
          • St. Louis
          Well I am sorry to say that the stators tend to take a dive on the 400 at about 14,000 miles. Its just the vibration. They usually pop up on ebay every once in awhile. Sorry to hear about yours. I really liked my little 400.
          DJ
          "Imagination is more important than knowledge. Knowledge is limited; imagination encircles the world." -Albert Einstein
          • wessdogg
            • 8
            • Akron
            I know a seller on ebay that you can get parts on, if your interested let me know.
            To be the best, you got to beat the best!
