Hi Guys,
I promised to host some pictures as soon as I got her. I still have to polish her up a bid, she's still covered with a lot of dust.
OK:
XS1100
And for the ODO reading:
ODO
And as for the bike was not driven for five years, the first problems already rearing their ugly head.
First of all, taking the bike from it's center stand was easy, moving the bike was a total different story. All Brakes were stuck.
So took all brake callipers and master cylinders off. Cleaned them conpletely and flushed the brake lines. Mounted them back again, put new brake fluid in the resevoirs and bled the brakes. And guess what, all fine again.
Second
Went over the electrics, all OK.
Installed new plugs, all were sparking so ignition OK.
Thirds
Drained all engine fluids, meaning engine oil and the carbs. The carbs were completely dry, oopss.
Took the carb rack out and opened up the float bowl resevoirs. Completely full with gum, crud, dried out fuell residual. Managed to get all nozzles, jets, needles, diaphrams out in one piece. Cleaned them all, opened up all holes in the carb.
Builded the rack back in and was ready to fire her up.
Drained the gastank, refueled it.
Fired her up, and she was running, correctly at 1300 rpm.
As soon as she was warmed up, I closed the choke. Instead of running on all fours, she was running only on two cyls. Checked for ballance, sync and cyl 2 and 3 were on full vacuum. I tried to adjust this but nomatter what I alter, the situation stays except when I put the choke back on, then she runs on four. Also above 3k she runs on all fours. Don't think it's ignition related because she's running fine on all four at 1000 rpm with the choke still on.
I'll go over the pilot jets again and see what's wrong, maybe I missed something on those carbs.
Anyone any experience with Mikuni carbs and thes symptoms on other bikes ??
Thanks,
the Dutchy
OK:
XS1100
ODO
Second
Thirds
Thanks,
the Dutchy
