Dumb-a%$ Award
1980 XS 1100SG
Dyna 3 Ohm Hi Output Coils
Pod Filters
DynoJet Kit
T.C.'s Fuse Block
V-Max Auto CCT -
cam chain tensioner issues....
hey there mrozz....was in your situation once.....have learned that a picture on here is worth a thousand words.....here's what you are looking for and how it looks going in.....fzr tensioners are a plenty on fleabay......but here is the documentation of my experience.....
read through it and you will find me doing the cct......with pictures!!!!.....what a novel idea!!!!.....hope this help and hit me up if you have questions!!!....ride hard, ride safe....rossrebel devil
1979 xs 1100f standard
authenic historical vehicle
42°36'23.52"N, 82°52'44.78"W
"I'M IN MY HAPPY PLACE"
"i got 14 jobs mon....you only got 1 job....you lazy bones mon"
"if you don't wrench on it, get behind me satan!"
'96 venture cct.....installed!
stainless, braided, pvc coated brake lines
i can translate...deustch, nederlands, 汉语, 漢語, français, ελληνικά, italiano, 한국어, português, русско, español and most importantly, 日本語....Comment
Good info there.Four wheels move your body, two wheels move your soul.
1980 XS 1100SG
Pod Filters
DynoJet Kit
T.C.'s Fuse Block
V-Max Auto CCTComment
Letting Go is hard to do!!!!
In the 70's as a teenager talented ridding wheelies in front of the girls next door shifting from 2 to 3 on my dirt bike I had the thottle cable lock wide open. Being talented as I was I just let it go landing in the gravel driveway. Slidding in a bent knee position I didn't fall. Feeling like a god raising to my feet seeing them standing and yelling I held my arms high into the air in victory.
The Girls seeing that my friend had went down the road falling over on a footpeg spinning arround bouncing up doing a perfect wheelie then leveling on the road like a homed in missile my buddy was comming back for me. They yelled they screamed they ran to greet me.
Me doing my victory dance knew nothing till EEEEEEEEEEEEEEEEE Whap the headlight hit me in the thigh knocking me up in the air tumbling down victory lane.To fix the problem one should not make more assumptions than the minimum needed.
Rodan
1980 G Silverbird
1198 Overbore kit
Grizzly 660 ACCT
Barnett Clutch Springs
R1 Clutch Fiber Plates
122.5 Main Jets
ACCT Mod
Mac 4-2 Flare Tips
Antivibe Bar ends
Rear trunk add-on
This one only happened last month.
I was repainting my girlfriend's Honda 450 Rebel, we had done an awesome rust stripe up the center of the tank, and black on the sides, and I had the tank sitting on a 5-gallon bucket while I was wetsanding before the final coat. That was how I did all the coats, so it shouldn't have been a big deal, right?Wrong!
I had both hands on it the whole time, keeping it centered on the bucket, then I lean over it to sand a small area on the far side under the tank, and end up pushing the damn thing off the bucket toward myself right onto the concrete!I put a softball sized dent right in the side, chipping the paint off all the way down to the metal!
If you think it's bad screwing up your own bike, try screwing up someone else's! Luckily she loves me, and didn't kill me, but I've got a lot of work ahead of me trying to get it fixed.-Whatever it is, it's better in the wind.
1980 XS1100SG - "Bluesy Suzy"
-Oil cooler
-TKAT Fork Brace
-Drilled Airbox w/ K&N
-Engine guards
-Speed Bleeders
-TC's blade fuse block (waiting to be installed)Comment
Don't go to sleep misfit.....Greg
The list changes.Comment
My turn
Hi,
I'm new here, and what better way to start things off than with how dumb I can be?
Did this today:
riding int the rain, which my bike does not like, bike died twice at stop lights and just made it to a parking space before died for the third time. Sounded to me like it might be misfiring, so I put my hand over the pipes to see that all was firing. Don't have a clue why, but on the last pipe, instead of just holding my hand over the pipe, I grabbed it with my left hand. Have a blister roughly the size of a VW rabbit (classic) on the joint between thumb and forefinger. On the plus side, the rain stopped and the bike made it back to work fine, so I guess that's all that matters1981 XS 11 special
red
40,000 milesComment
Sputtering in the rain could be a few things. If it's electrical you can check
Spark plugs and secondary ignition connections
Ballast resistor and primary ignition connections
Wiring harness that runs along the left side of the engine next to the shift lever. That harness has the wires from the pickup coils and if water gets through a crack in the plastic covering the wires it can short the crimp connectors for the pickup coil wires until the water dries out.-- Scott
♬Comment
Also
There is a neutral switch on the left side bottom in the same bundle as your pickup wires. This usually gets dirty fast and when it gets wet it conducts very good and will effect the ignition when you put it in gear I discovered this when I go to the pressure car wash. Bike runs great when wet until I put it in gear and it then stops.You can't stay young forever, but you can be immature for the rest of your life...
Drilled airbox
Tkat fork brace
Hardly mufflers
late model carbs
Newer style fuses
Oil pressure guage
Custom security system
Stainless braid brake linesComment
My Turn
I was balancing the carbs last Sat and had the tank off, turned around, and hooked up. I have large hands so hooking up the hoses to the carbs is not much fun. I get a brainstorm, I'll unhook the lines at the tank, get it in place, lift the back and easily reattach the hoses. I turn the tank around, run the hoses across under the carbs, and turn on the petcocks to check for leaks. My next semi-intelligent thought is, "why do I smell gas?" Cause it's running out of the hoses I didn't hook up you moron. Now have a puddle collecting on the garage floor and dripping off the engine. Now I gotta throw down floor dry, sweep that up, and answer the wife's questions as to what happened and why can't we go riding right now.1979XS1100SF
K&N's and drilled airbox
Jardine 4in1
Dunlop Elite 3's
JBM slide diaphragms
142.5 main jets
45 pilot jets
T.C.'s fusebox & SOFA
750/850 FD mod.
XV 920 Needle Mod.
Venture Cam Chain TensionerComment
