newbe
  • greg
    • Mar 2006
    • 2
    • south wales
    newbe
    hi all
    just a quick intro to say hi.
    and now to the serious bit can any one help me find tank mounting rubbers for my xs1100 1982 us import.
    removed the tank to find a petrol leak and found the mounting rubbers had gone.
    thanks all
  • mro
    • Oct 2005
    • 4276
    • Hayward, California
    rubbed wrong way?
    Hi greg,
    welcome to XS land
    think most oem rubber is getting hard to find.
    should not be too hard to fashion new ones.
    can get rubber from seal/gasket company.
    punch/drill center hole, put bolt/washers through hole w/nut and put end of bolt into a drill motor. Shape rubber with a "rasp" (rough wood working file). sand paper will smooth it out.
    would not look oem, but hard to see under tank
    mro
    • xswilly
      • Jul 2003
      • 462
      • Hollis, maine
      or just go to the local sports store and get a couple of hockey pucks, drill a hole in the middle and cut the outside down to size,
      you can prob do it on a bandsaw, or lock your jigsaw in a vise upside down, cheepmans bandsaw
      http://home.securespeed.us/~xswilly/
      79F Parts
      80G Parts
      75 DT 400B enduro
        The Yamaha part number for the "fuel tank locating damper" is 1J7-24181-01-00 DAMPER, LOCATING 1. As it's a 1J7 part number, it is probably still available. If not the exact one, you should be able to find something close, and then modify as needed.
        Welcome to the club, and don't forget to hold on TIGHT as you twist the throttle.
        Ray
        • andreashweiss
          • 951
          • 180 mile northwest of Spokane,WA
          I have some of those, Do you mean the two round rubber pieces that have a centre hole in them that fit on the frame close to the triple tree that the tank hangs on? andreas Weiss P.O box 1218 Oroville,WA 98844
            No wonder you were leaking, no rubbers!
            Hey Andreas, do you ship internationally? Greg is in South Wales, I reckon that's on the British Isle?
            Greg, Bike Bandit has them for a bit over $7.00 ea US:
            BikeBandit.com
            5: DAMPER,LOCATING 1 10994-001 $7.36
            MikesXS which sells 650 parts has some for around $3.00 ea, but they are a bit different than the XS, but there is a distributor in the UK/EUROPE, might be more adaptable and cost effective than the BikeBandit ones?
            Gas Tank Mount Rubber
            Gas Tank Mount Rubber - Front - Fits: All 650’s 1970-84
            Part #02-6530 $3.00 USD EA.
            BTW, Welcome to the Madness!
            • andreashweiss
              • 951
              I have three complete sets of 2. Thinking they will fit in a small envelope and go over da pond pretty cheap. Send me $10.00 will send 2 over including shipping. andreas
              • mro
                • Oct 2005
                • 4276
                Hey andreas
                you don't happen to have the rubbers in the turn signal mounts do ya
                80 standard
                mro
                • LoserShoes
                  • Apr 2005
                  • 524
                  • Bangor Maine
                  Those were still available from Yamaha about a year ago.
                  Steve
                  80 XS1100G Standard - YammerHammer
                  73 Yamaha DT3 - DirtyHairy
                  62 Norton Atlas - AgileFragile (Dunstalled) waiting reassembly
                  Norton Electra - future restore
                  CZ 400 MX'er
                  68 Ducati Scrambler
                  RC Planes and Helis
                  • andreashweiss
                    • 951
                    Are you talking about the rear signals, the frame rubber mount with the chrome piece inside. andreas ??? Yes.
                    • greg
                      • Mar 2006
                      • 2
                      • south wales
                      thanks all some good advice/info comeing through.
                      andreashweiss
                      can you send me a email with your contact details ect ?
                      the rubber i need most is the one neer the seat that holds the tank to the frame the front ones seem ok.
