Replacement Fuse Blocks and Possibly TERMINALS
    • 3918
    Originally posted by BowlingSS
    I am interested in the fuze block & the 90 degree "Flag style" 0.250" terminal connector. Please send me your paypal email if you are still selling these.
    Thanks.
    Bill
    Hi Bill-
    Send a PM to TopCat, and he'll hook you up with the fuse block and flag terminals.
    • CaptonZap
      • Jun 2010
      • 1748
      • Denver
      #137
      If it makes you feel any better, TC doesn't make any money on the kits he sells, he just does it for the love of the game.
      CZ
      • LoHo
        • Sep 2002
        • 1342
        • Fresno, CA
        #138
        Of all the mods people consider, this should be first and foremost. It is fairly easy and solves a host of hard-to-find problems down the road.
          • 7859
          If it ain't broke, don't fix it! Do it wrong and you can introduce new problems. Yes, when it's time to replace the box, spade fuses are the way to go.
          • LoHo
            • Sep 2002
            • 1342
            • Fresno, CA
            #140
            If it ain't broke, it's still 35 years old, and made of plastic, brass, and glass. I generally agree with the "wait until it fails and fix it" idea, but I think this is pretty pro-active. I'd hate to have an intermittent electrical problem to chase around because a glass fuse had mostly failed, but worked well enough to screw me around.
              • 7859
              I bring it up because you can take the right side cover off of many of the bikes that have this modification and pull the wires out of the flag terminals. Mine was one of them! There is one way to do it right and several other ways to just get it done. Some work fine and last a long time, others, not so much.
              This was just posted in another thread. (Ugly duckling rebuild) It looks like a nice clean installation. I'd like to know a little more about how the wires are terminated.
              • Gmac
                • Aug 2014
                • 256
                • Huntsville, AL.
                #142
                Those are
                Individual fuze holders, not the terminal block that TC farms.
                Very water proof.
                79 SF & 80 LG MNS
                73 & 74 RD 350's
                73 Honda CL 450
                Graveyard - '81 XS850 Special
                • LoHo
                  • Sep 2002
                  • 1342
                  • Fresno, CA
                  #143
                  Hey Gmac, if that is a superior method, which manufacturers use individual in-line fuses?
                    • 7859
                    LoHo,
                    I hope it's OK if I answer. Here is the response I receive in the ugly duckling thread.
                    I used the OEM fuse holder and four individual ATM fuse holders from Autozone. I removed each OEM fuse and the associated wires one-at-a-time. I cut back several inches of the OEM wire bundle wrap and s,pliced, soldered and heat shrunk each connection. I varied the lengths of the pre-wired ATM fuse leads so I didn't end up with a bug lump in any one location. You can see one or two of the soldered shrunk connections on the left side of the box, the remainder are up under the re-wrapped main bundle.
                    Each individual fuse holder is double zip tied to the OEM fuse base at the location of the original glass fuse using the area where the fuse clip use to attach. I used wire marker wrap to maintain an I.D. of each wire and also marked the fuses with: "M 30" (Main), "H 10" (Headlamp), "T 20" (Turns Sigs), "I 10" (Ignition)
                    Kurt's job looks very good to me. If I had done it, I would have used high temp (uninsulated) butt splices because it's easier for me to do a good job that way. I find doing a good solder joint to be a PITA. There's nothing wrong with it when done properly.
                    I did mine with TC's box and used the flag terminals. I now have a flag terminal crimper and those joints are good. They aren't easy to crimp without a proper tool. The wires would pull right out of my original installation. I have seen others do the same.
                    If you did an installation like Kurt's and did a poor job of crimping butt splices, particularly insulated butt splices, the final product would not be any better than poorly crimped flag terminals.
                    The one that's better is the one that's done right. The Autozone boxes are waterproof. I backed my TC box with a piece of rubber, so it's protected as well. It doesn't get wet behind the side cover anyway on a stock bike.
                    • Gmac
                      • Aug 2014
                      • 256
                      • Huntsville, AL.
                      #145
                      Dunno LoHo
                      I've never seen a manufacturer use individual inline fuzes to create a fuze block, just individual usage. They are the blade type fuze in a snap tight enclosure that is waterproof. YMMV
                      79 SF & 80 LG MNS
                      73 & 74 RD 350's
                      73 Honda CL 450
                      • LoHo
                        • Sep 2002
                        • 1342
                        • Fresno, CA
                        #146
                        I think that, like most things on these bikes, there are a few ways that work and a million that suck, and that a good method can be ruined by crappy workmanship (like my solder joints). Most guys promote the way they do it, and a few disparage any other methods.
                        I was just saying that the TC fuse box is a good choice for someone with the old brass and glass fuses. And there is more than one way do it right. The TC box, or something similar, works well. That one above with the red wires looks professional and I'd have that guy do electrical on my bike anytime.
                          • 7859
                          I have to agree.
                          • BowlingSS
                            • Apr 2015
                            • 398
                            • Lawrenceville, GA.
                            #148
                            Getting ready to install the TC fuse holder as soon as I get the parts.
                            Bill
                            Jardine Spaghetti with Harley Mufflers
                              #149
                              Hey Bill,
                              You got my email notification of the delay didn't you? You should get it in the next few days. Some Bored USPS worker decided to actually WEIGH the little 3 oz package, and probably did it wrong since it had 4 stamps on it! I've mailed hundreds of them with only 4 stamps on them without any problems.
                              • BowlingSS
                                • Apr 2015
                                • 398
                                #150
                                Hey Bill,
                                I got it. Thanks TC.
                                Bill
