gas tank help
  • bandet01
    • 698
    • connersville indiana
    gas tank help
    ok here goes guys i was out working on the bike this weekend making sure it would start and run since i aint got a garage and it has been cold and snowing out but the bike is under a cover, but my problem is the cover was not on for a week and it snowed and my gas tank lid had water in it and when i opened it to see how much fuel was in it there was water in there too so i think the fuel got water in it but i got some stuff put in it and some seafoam to clean the carbs and the fuel sytem and the engine out and i put some 94 octane in the tank and this summer when i get it out i am going to go put some 104 octane in it, but my main question is is there anyway to keep water or over spilled fuel from pilling up under the gas tank lid
    the bike is under a cover now and it ran great so i am just waiting tell spring time now to ride
    79 yamaha xs1100f standard
    best 1/4 mile 13.282@99.40
  • Pat Kelly
    • 3046
    • Golden Valley, AZ
    There should be a drain from under the fuel lid (in the recessed area) that is a tube that goes inside the tank and out the nipple at the back of the tank (under the seat).
    Could be this drain tube is clogged.
    Pat Kelly
    <p-lkelly@sbcglobal.net>
    1978 XS1100E (The Force)
    1980 XS1100LG (The Dark Side)
    1999 Suburban (The Ship)
    1994 Dodge Spirit (Son #1)
    1968 F100 (Valentine)
    • bandet01
      • 698
      thanks pat i will have to look into the when i take the lid off for paint how would you replace that line if it is clogged
      • mro
        • 4276
        • Hayward, California
        did you get all the water out?
        if water out, add stabilizer to gas
        run engine for short time to get stabilizer in to carbs
        or park in living room
        mro
          • 7619
          Bandet01,
          If you pull the seat, you will see a tube on the back of the tank. This is the drain from around the fill cap, and drains the water to the bottom of the bike. I have a bike that was parked for 10 years, and the drain is still working. Unless you have a LOT of rust around the tank, your drain should still be working.
          An easy check is take some warm water( because it's cold up there) and pour it slowly over the gas cap. You should see the water come out on the bottom of the bike, about at the center stand.
          Ray
          • mro
            • 4276
            An easy check
            If seat off
            why not just blow through other end of hose to see if clear?
            btw
            is your tranny fixable with the grinding etc. I read in other posts?
            • mro
              • 4276
              DriverRay
              btw
              need place brain in gear before typing
              mro
              • bandet01
                • 698
                ok i will have to try that next time i work on the bike and see if it is clogged or not and pour some water down it and hope it aint and i did put some iso heet in it and some seafoam and some 94 octane fuel in the bike and let it run for a half hour so this spring i am going to go run the bag off it ang then put some 104 octane in it and run that and then from there on out put 93 or 94 octane in it
                  • 7619
                  mro;
                  My trans may be repairable, but it's getting BAD. I've ordered a trans from Andreas, and three gears from Yamaha. I think my project bike also has a bad transmission, so I want spare parts. I plan on putting in the parts starting on the 30th of December. I will be checking gears, and doing any needed grinding.
                  Ray
