1980 xs1100 SG petcock adaptors
  • halfbreed
    • Apr 2010
    • 31
    • Ohio
    Hi, i was wondering if anyone has used these petcock adaptors to us a standard 3/8 NPT petcock, there seems there isn't any non-vacuum replacements for this year or model, except if some can tell me someplace that has them
    • 1910
    I have no experience with the adapters but many have used these Yamaha Xs1100 Petcock for sale | eBay and stated they work ok.
    • halfbreed
      • Apr 2010
      • 31
      • Ohio
      the petcocks that are listed will work for anything not the 1980 special the bolts are not the same size bolt to bolt
        • 1910
        My bad... didn't really look close enough. Try this listing ... the first two say they work. Fuel Petcocks & Taps 1980 Yamaha Xs1100l Midnight Special in Fuel Petcocks & Taps for sale | eBay
          • 1818
          I really like those manual petcocks. Very reliable and easy to use.
            • 7941
            Petcock - Right Hand OEM type 1970-77 XS650 Petcock - Right Hand - Original Non-Vacuum Manual Type - (3 Screw Rear Cover). Includes: Tap to Tank O-Ring. Replaces All Original Right Non-Vacuum Types used on 1970-77 650's This petcock will not fit 64-7702 gas tank.   Part #20-0051 $29.95 Ea.
            Petcock - Left Hand OEM type 1970-77 XS650 Petcock - Left Hand - Original Non-Vacuum Manual Type - (3 Screw Rear Cover). Includes: Tap to Tank O-Ring. Holes are 42.5mm Apart. OEM Ref.# 447-24500-02. Replaces All Original Left Non-Vacuum Types used on 1970-77 XS650's. This petcock will not fit 64-7702 gas tank.   Part #20-0050 $29.95 Ea.
            I have some of these. I can check the spacing. I believe they fit the Eleven Special. The Midnight has the same petcock as the other Specials, correct? These petcocks won’t allow the use of the vacuum shutoff valve.
              • 1376
              The adapter plates like shown were great! (^_^)
              Until they W E R E N ' T. (_Oo)
                • 774
                To me it's worth the time and effort to get a working set of vacuum operated petcocks on my bike. Had a Suzuki that was converted from vacuum to manual and never having to remember to turn the fuel off keeps you from waking up to a huge fuel leak along a puddle under the bike and a need to change the oil due to a flooded crankcase.
                  • 1818
                  Larry, those look like they were not normally used. They look like they were still installed during a vinegar or acid wash. Also could of had quite a bit of moisture on the bottom of the tank and sat all winter. VERY unusual amount of corrosion.
                  Here is mine after a year on the tank. No issues. Quite a difference.
ID:	883452 Click image for larger version
ID:	883453 Click image for larger version
ID:	883454 Click image for larger version
                    • 1376
                    "Larry, those look like they were not normally used. They look like they were still installed during a vinegar or acid wash. Also could of had quite a bit of moisture on the bottom of the tank and sat all winter. VERY unusual amount of corrosion."
                    Usage wuz normal. (^_^)
                    Just installed years ago as a "Well, now petcocks wurky so's move on to sumpthin' elso on the to do list." (O_O)
                    No acid or vinergar wash while petcocks/plates installed. I did a wash/rinse on the tank AFTER the plates failed but I made a set of "blocker" plates/gasket to close up the opening(s) in the tank where's the petcocks/plates wuz s'posed to be. ┐(´~`)┌
                    Bike DID sit fOaR 8 months whilst I went on a non-bike trip/adventure. Prior to leaving I did a "soft lay up" of the bike. Drained float bowls, added fuel stabilizer to a full tank of gas, lifted the bike off'in the tires, etc. 乁( ⁰͡ Ĺ̯ ⁰͡ ) ㄏ
                    The petcocks you show are not the type that use the squarish "adapter plate" pictured at the start of this thread, don't use the same full rubber rectangular gasket, and most importantly the petcock is not a seperate unit what screws INTO the adapter plate. (^_^)
                    You might be fine and stay that-a-wayz. (O_o)
                    Imma sticking with the latin phrase- "res ipsa loquitur". ¯\_(⊙_ʖ⊙)_/¯
                    As in, "The thing (picture) speaks for itself." (°_°)
                    Imma callin wut I pictured as the "Usual" thing to see afters these adapter plates are installed fOaR a while as opposed to the shiney new photo befOaR anyone "adds-to-cart". ┐(°ヮ°)┌
                      • 1910
                      Seems I have not been any help to the OP. These don't appear to be non-vacuum. Of course for me they would work perfectly because I prefer vacuum operated.
                        • 1818
Name:	Opera Snapshot_2025-02-28_034836_www.ebay.com.png
ID:	883486 Click image for larger version
Name:	Opera Snapshot_2025-02-28_034752_www.ebay.com.png
ID:	883487 Click image for larger version
Name:	Opera Snapshot_2025-02-28_034437_www.ebay.com.png
ID:	883488 Click image for larger version
Name:	Opera Snapshot_2025-02-28_033144_www.ebay.com.png
                          • 1910
                          Awesome post Deebs. I am sure the OP and others appreciate it. I do.
