XS1100 Replacing Crown Nut on Cylinder Head
    • 1493
    Has anyone had any experience replacing the four outer crown nuts on cylinder head by removing one nut at a time, installing the new part and re-torqueing before moving to the next one? I'm familiar with the textbook answer which is if you loosen the torque the head gasket could breech/head warpage but what I'm looking for is people who have actually done this and had success or failure with a decent amount of mileage on the motor after the retrofit.
    • 8672
    Taking off one at a time and replacing will not hurt anything. The torque value is only 25 ft/lb. Apply oil to the threads before torquing. Yes I have done this.
      • 1951
      I've wire brushed them with a Dremel tool and painted them Rustoleum silver. They came out pretty decent if that's what you are looking to improve.
      • XJkid
        • Jun 2003
        • 280
        • Elk Grove, Ca.
        I have done it, too. No issues.
          • 1493
          I'm glad this has worked for a few of your motors. I am going to give it a try.
            • 695
            Mine are looking pretty crusty, thanks for the info!
            • mlew
              • Jun 2005
              • 226
              • Apex , NC
              I did mine the same way. replaced with stainless acorn nuts
              Slow down and enjoy life. If you are in that much of a hurry, you should have left eariler.
              Current rides:
              80 XS1100SG
              82 JX1100
              83 Venture Royale
              86 V-Max
                • 1493
                Do you remember the size and thread pitch? Is it M10 x 1.0mm?
                  • 8672
                  Acorn nut is M10X1.25
                    • 695
                    Easy enough!
                      • 8672
                      Not too many farkles still available for our bikes
                        • 1493
                        Thank you, gentlemen. Very helpful info.
