XS1100 TCI inner workings
+ More Options
Posts
    • 1459
    This is a look into the Yamaha XS1100 TCI or Transistorized Control Ignition. Today it would be referred to as an ECU or Electronic Control Unit. The unit uses a sensor which is a tiny coil of wire mounted down on the left side of the bike. 2 sensors total 1 for each coil. When the magnet or "reluctor" passes each of the two tiny coils of wire inside the sensor, it sends current to the base of each transistor. The transistor then turns on like a tiny relay and grounds the large ignition coil for a short period of time. During this time, the coil charges up and then releases a huge burst of stepped up voltage that can actually jump the small gap at the end of the spark plug. All timed perfectly with mechanical devices.
    Here is a diagram that's a little more in depth in comparison with what they provide in the service manual. The colors highlight some more detail in the circuit.
    Click image for larger version  Name:	image_4087.jpg Views:	1 Size:	103.9 KB ID:	875120
    • 1459
    The transistors in the TCI are NPN or "Negative-Positive-Negative".
      • 1459
      This is how the transistor in the TCI makes spark.
Name:	XS11 TCI Schematic.jpg
        • 1459
        To remover the circuit board you must de-solder the pins that go to the spade connectors that are potted to the TCI plastic housing. The spade connectors are not removable and are easily destroyed if overheated. Conformal coating is used to protect the circuit from weather. It's a clear type of epoxy that must be removed and replaced after any repairs are made. These chemicals are available through electronic supply vendors.
ID:	875127 Click image for larger version
ID:	875128 Click image for larger version
          • 1459
          A guide to what wire goes where on the TCI plugs.
            • 1459
            De-solder pins and carefully remove circuit board.
ID:	875133 Click image for larger version
ID:	875134 Click image for larger version
              • 1459
              The actual TCI board. The two large silver circle items are the old fashioned transistors. Lots of capacitors. A few small transistors. Lots of resistors. A few diodes.
ID:	875137 Click image for larger version
ID:	875138 Click image for larger version
ID:	875139 Click image for larger version
ID:	875140 Click image for larger version
                • 1459
                Someone on-line posted this schematic on the XS1100 TCI. It is in German but can still be followed from known pin-out information.
                • XJkid
                  • Jun 2003
                  • 280
                  • Elk Grove, Ca.
                  You guys are Geeks.
                    • 1459
                    This is a very basic path for output the ignition coil. Start at the left with the sensor and all the way through to the large ETD32 transistor. Many smaller transistors involved.
                      • 1459
                      If you have only one coil working and have traced it back correctly to this TCI then the problem is more that likely one of the big transistors. The clue is the huge heat sink on the devices. Usually the first part to fail in a circuit is one that gets hot.
ID:	875148 Click image for larger version
ID:	875149 Click image for larger version
ID:	875150 Click image for larger version
                        • 1459
                        ETD32-035B. TO-3 configuration. Anybody know of a resource for this part? I'm sure it just about impossible to find. Probably went obsolete in the 1990s. Must be some on a shelf somewhere.
                        • Mathh
                          • Nov 2006
                          • 665
                          • Beek, Netherlands
                          Well, I googled and found this: https://www.transistorall.com/transi...rch=ETD32-035B
                          MV Agusta Brutale 910R '06.
                          Yamaha MT-09 Tracer '15 grey.
                          • dansmith65
                            • Aug 2017
                            • 138
                            • Kootenays, BC , Canada
                            I love that you're doing this! Here's what my quick google search turned up:
                            80 SG Canada
                              • 686
                              Wonder if it wouldn't be easier to try mapping the input and output and running it with an Arduino?
