One thing hotter coils won't do for you is stop the high-RPM break down of spark voltage. Just comparing spark voltages is not telling the whole story. With the MSD spark voltage will be constant throughout the RPM range and you will be able to run a larger sparkplug gap to get more fuel in the spark for better ignition.
I'd put this setup on my bikes too but the price is way more than I can justify. Fortunatly their auto units are more affordable and I put them on my cages as I can swing the funds. One of these did wonders for my old 240Z.
Geezer
Geezer
The 'hype' from MSD is that the stronger and longer duration of their spark pulses cause more complete combustion which translates into more engine power cause you're getting more work out of the same amount of fuel/air mix than you normally would with OEM ignition.
