xs1100 Where do these parts go?
  • MotoPoesy
    • 12
    • Pittsburgh
    Wisdom seeking today.
    Piecing together a 1980 xs1100 Special and wondering where these items go?
    The cable clip seems to belong on the cam cover somewhere, i've seen a diagram that shows it front and center but all I see on the bike there is the oil cooler, no cable to hold.
    And the two rubber bullets, yeah I've no clue :/
    • 2085
    2nd pic is where the throttle cable is routed. That what the part looks like.
      • 8074
      I don't recognize the rubber bullets. That clamp mounts with a valve cover bolt and the throttle cable goes through it as stated by oldyam80sg .
Name:	Screenshot 2022-07-16 101947.jpg
      It's #20 in the illustration.
        • 2085
        Do the bullets cover up the screws that are set at the factory they don't want you to play with such as mixture screws?
          • 2085
          If the bullets are rubber are they fancy vacuum caps?
            • 7828
            Factory air caps don't have the smaller diameter on the base. They are the same diameter all the way down. They will also be VERY HARD, and not work well if they are the OEM caps!
              • 2085
              aftermarket?
              • MotoPoesy
                • 12
                • Pittsburgh
                After scanning many "misc. parts" ebay listings and not seeing these things in any collection I'm of the opinion the PO just got them mixed in with the random everything I walked out with. These go into the cold case files. My thanks for the guesses all the same.
                  • 2101
                  Those rubber pieces look like fork bump stops similar to the ones on my Husqvarna 250
