This is a 91 Z28. a/c compressor started making this noise only when clutch is engaged. And it starts smoking. If I shut the a/c off it doesn't make any noise. I can't tell exactly where the smoke is coming from. It makes cold air. I can't get the video to load here go to my FB. What is bad? The clutch? The compressor? Both? Ideas.
a/c compressor noise
79 SF parts bike.Tags: None -
Jim... went to your facebook page and there is no video. I suspect that if you did post it you did not make it public.This is a 91 Z28. a/c compressor started making this noise only when clutch is engaged. And it starts smoking. If I shut the a/c off it doesn't make any noise. I can't tell exactly where the smoke is coming from. It makes cold air. I can't get the video to load here go to my FB. What is bad? The clutch? The compressor? Both? Ideas.
https://www.facebook.com/jim.sisler.5/2 - 80 LGs bought one new
Jim -
Most likely the clutch needs rebuilt. I have had a Jeep's AC compressor SCREAMING but I was able to find a rebuild kit. About an hour is all it took to replace the clutch and wire it in.1980 XS1100G "Dolly G" Full Dresser (with a coat of many colors
You should be able to view it now. I'm guessing it's just the clutch. With the belt off the pulley spins free & I can turn the compressor easily. If it's just the clutch would you replace the coil also?Last edited by red bandit; 05-23-2022, 05:11 AM.79 F full cruiser, stainless brake lines, spade fuses, Accel coils, modded air box, 750 FD.
79 SF parts bike.Comment
I think it's the pulley bearing that has or is going bad. Here is a youtube video addressing your problem on another type of vehicle. Noise is the same though. AC Clutch Repair and Noise Diagnosis -EricTheCarGuy - YouTubeh.2 - 80 LGs bought one new
JimComment
If it was the pulley bearing wouldn't it make noise with the a/c on AND off? And how would that make smoke? I know in the video it sounds like a bearing but in reality is sounds more like clutch chatter but I don't know?? Anyway, would you replace the coil if you are replacing the clutch?79 F full cruiser, stainless brake lines, spade fuses, Accel coils, modded air box, 750 FD.
You will not know for sure until you disassemble it.If it was the pulley bearing wouldn't it make noise with the a/c on AND off? And how would that make smoke? I know in the video it sounds like a bearing but in reality is sounds more like clutch chatter but I don't know?? Anyway, would you replace the coil if you are replacing the clutch?2 - 80 LGs bought one new
JimComment
I removed the old a/c clutch today. The matting surfaces were very rough. Everything was dry. So I put the new clutch w/ coil on today & ran it with a/c on max & fan on high for about 25 minutes and everything was quiet and it was blowing ice cold air. "smiles". Time will tell. But it looks like it's fixed. It rained last night so my road is mud otherwise I would have taken it for a ride. Maybe tomorrow. Thanks for the help.79 F full cruiser, stainless brake lines, spade fuses, Accel coils, modded air box, 750 FD.
