a/c compressor noise
  • red bandit
    • 955
    • central michigan
    This is a 91 Z28. a/c compressor started making this noise only when clutch is engaged. And it starts smoking. If I shut the a/c off it doesn't make any noise. I can't tell exactly where the smoke is coming from. It makes cold air. I can't get the video to load here go to my FB. What is bad? The clutch? The compressor? Both? Ideas.
    Jim Sisler is on Facebook. Join Facebook to connect with Jim Sisler and others you may know. Facebook gives people the power to share and makes the world more open and connected.
    79 F full cruiser, stainless brake lines, spade fuses, Accel coils, modded air box w/larger velocity stacks, 750 FD.
    79 SF parts bike.
    • 1909
    https://www.facebook.com/jim.sisler.5/
    Jim... went to your facebook page and there is no video. I suspect that if you did post it you did not make it public.
      • 2083
      Most likely the clutch needs rebuilt. I have had a Jeep's AC compressor SCREAMING but I was able to find a rebuild kit. About an hour is all it took to replace the clutch and wire it in.
      • red bandit
        • 955
        • central michigan
        You should be able to view it now. I'm guessing it's just the clutch. With the belt off the pulley spins free & I can turn the compressor easily. If it's just the clutch would you replace the coil also?
        79 SF parts bike.
          • 1909
          I think it's the pulley bearing that has or is going bad. Here is a youtube video addressing your problem on another type of vehicle. Noise is the same though. AC Clutch Repair and Noise Diagnosis -EricTheCarGuy - YouTubeh.
          • red bandit
            • 955
            • central michigan
            If it was the pulley bearing wouldn't it make noise with the a/c on AND off? And how would that make smoke? I know in the video it sounds like a bearing but in reality is sounds more like clutch chatter but I don't know?? Anyway, would you replace the coil if you are replacing the clutch?
            79 SF parts bike.
              • 1909
              You will not know for sure until you disassemble it.
              • red bandit
                • 955
                • central michigan
                I removed the old a/c clutch today. The matting surfaces were very rough. Everything was dry. So I put the new clutch w/ coil on today & ran it with a/c on max & fan on high for about 25 minutes and everything was quiet and it was blowing ice cold air. "smiles". Time will tell. But it looks like it's fixed. It rained last night so my road is mud otherwise I would have taken it for a ride. Maybe tomorrow. Thanks for the help.
                79 SF parts bike.
