1/2" impact wrench
  • red bandit
    • 950
    • central michigan
    1/2" impact wrench
    It's time to buy a 1/2" impact wrench. Just for home use a half a dozen times a year at the most. I don't need the best one on the planet but something that will take off lug nuts with out a problem. I know some claim to have 1300 ft/lbs. of toque. I don't need a broken wrist. This one claims 350 ft/lb of working torque. I know that's enough torque for what I need but do you think it actually has that much torque? Suggestions?
    Ingersoll Rand 261 Air Impact Wrench 3/4" Drive Super Duty. Torque in Reverse ft-lb: 600 reverse bias. Working Torque Range ft-lb: 25-350. Air Fittings/Couplers. Average Air Consumption cfm: 4.2. Air Consumption @ Load cfm: 22.
    79 SF parts bike.
  • 2WheelFun
    • Aug 2020
    • 266
    • Pittsburgh PA
    I'm sure that one would do the job. For as light of use as you describe, check your favorite classifieds and find a lightly used one for less than half that price from a hobbyist.
    1979 XS1100 Special
    1980 XS1100 Std parts bucket
    1987 ZL1000 Eliminator
      • 7597
      Try this one: https://www.harborfreight.com/air-to...nch-59185.html Yes, I know it says 800lbft, but the lighter one will NOT always do the job! I had their $50 one, and it has problems with stubborn bolts so I replaced it with one of these. Works well when I need it, and didn't break the bank.
        • 2070
        Your compressor has to produce adequate cfm's to run whatever tool you decide to purchase.
        I just picked up a barely used vintage B&D industrial 3/4" drive electric impact to remove the lug nuts on my dump truck which are torqued to 450 ft. lbs
        I have an I.R. similar to the one in your link but my compressor isn't adequate to remove more than one lug nut then I have to wait for it to recover.
        The impact is plenty strong enough though for anything on passenger cars or light trucks.
        • 2WheelFun
          • Aug 2020
          • 266
          • Pittsburgh PA
          I do have an earthquake and it has worked for me for the past year or so but I got it on a coupon day. I would go the I.R. over the Earthquake at the same price point and would still go used if a decent one was available.
          1979 XS1100 Special
          • dansmith65
            • Aug 2017
            • 138
            • Kootenays, BC , Canada
            I've been happy with this one, running it from a small compressor: https://www.amazon.com/gp/aw/d/B00UR...?ie=UTF8&psc=1
            I like the compact size; I assume that'll come in handy some day?
            80 SG Canada
            • red bandit
              • 950
              • central michigan
              I thought about the compact and plastic handle not getting so cold in cold weather (I would be in my pole barn) but it has a little less power so I going with my original choice. Thanks for all the input.
              79 SF parts bike.
