81 cylinder and pistons on a 1978 engine ?
  • Ronnie_D
    • 46
    • Airdrie, Alberta Canada.
    Hello:
    This is the only place that will let me add a new topic.
    Can I use a 1981 cylinder and pistons on a 1978 engine with a 1978 head?
    cheers,
    Ronnie.
  • JonnyO
    • Oct 2020
    • 229
    • Sun City West, AZ
    Originally posted by Ronnie_D
    Hello:
    cheers,
    Ronnie.
    Sorry, Ronnie. I don't know the answer to your question but had the same issue with adding a topic ...so good to know I'm not alone.
    I'm sure someone here DOES knows the answer...and will let you know shortly.
    -Jonny
      • 8904
      Well, basically that would be like using a 78 head on a 80-81 motor and yes it has been done before. The only difference between the early and the late motors is the pistons and the cams/head. You will raise your compression ratio doing this but from what I have read, there would be no piston/valve clearance issues.
      • Ronnie_D
        • 46
        Thank you bikerphil.
        That is good to hear.
        I am going to try it on my project.
        Ronnie.
          • 8904
          You're welcome. If you would like to do more reading on the subject of interchange heads and cams between the early and late motors, do an advanced search for posts from member Dan Hodges. He did a lot of experimenting in this area.
