Carb t
  • napioer
    • Oct 2020
    • 10
    • Port Elizabeth South Africa
    Carb t
    Hi all
    Has anyone got a sketch of part number 2H7-14988-00 . A brass T with four O rings that fits between the carbs. The original ones leak and Yamaha do not sell them.
    Thanking you in advance.
    Regards Mark
  • Bax
    • 344
    • Merrimack, NH
    napioer Hi, I don't have a sketch but you can repair the original fairly easily. Here is a link to video demo.
    The tees can be purchased from e-bay suppliers and MikesXS.net if you need. Seems shipping may be more of an issue to Elizabeth....
    ---Bax
      There is also this thread:
        • 1590
        Seems it got the complementary truncated clip. Clipped it short:
        Follow Forums / Repairs / Carb & Fuel System / Carb Tee Repair posted by jetmechmarty
        https://xs11.club/forum/repairs/carb...arb-tee-repair
        Probably the post that Ray was pointing to. Info if you want to mess with O' rings and fix it that way -or- get the new brass T's.
        Brass T's are a great way to fix it if you are so inclined but with Duty / VAT & TAXES plus Shipping a few O' rings works great too.
        Good Luck,
          • 2103
          Originally posted by napioer
          Hi all
          Regards Mark
          Fuel Tee Repair thread:
          Starting on post #8 of this thread is how I found a sufficient way to modify existing fuel tees almost five years ago and still no leaks.
          HTH
            Here is the all brass replacement for the one you have listed.
            Depending on the needs of other there is the second tee that is between the carbs and that is this one.
              • 2011
              HTH
              I used this method recently and the end of plastic piece on the tee came off. I had to utilize some Seal All to glue that piece back on and so far so good. Of course if I ever have to disassemble those carbs again I would suppose the glue might pull loose. No big deal... would just glue again.
              • napioer
                • Oct 2020
                • 10
                Thanks for your help guys have taken carbs off and will do the mod this .
