Cam chain tensioner plug
  • Filter
  • Cam chain tensioner plug
    Lost the rubber plug at the end of the cam chain tensioner, anyone found a sure fire way to replace this or even a glue that withstand the engine heat? It was loose before and I cleaned it up and used hi-heat liquid metal but that did'nt work obviously.....seems to me I recall years ago someone had a simple fix for this.....right now I'm at work, maybe someone will comeback with a suggestion before I ride home in the morning.
    Bruce
    78XS1100 Alpha
    Bruce Doucette
    Phone #1 902 827 3217
  • #2
    New ones are available from www.bikebandit.com
    Pat Kelly
    <p-lkelly@sbcglobal.net>
    1978 XS1100E (The Force)
    1980 XS1100LG (The Dark Side)
    1999 Suburban (The Ship)
    1994 Dodge Spirit (Son #1)
    1968 F100 (Valentine)
    • #3
      When I got my 80G it actually had a cork stuck in there. I have since replaced it with a rubber cork I got a real hardware store cost about 75 cents.
      Russ Neal
      Milton, NH
      04 GL1800 ABS
      04 Kawasaki Concours(Sold)
      99 Royal Star Venture(Sold)
      80 XS1000 Special(Sold)
      83 XJ750 Midnight Maxim(Sold)
      80 XS1100G(Sold)
      81 XS 650 Special(Sold)
      • #4
        RTV silicone will glue in a piece of cork or rubber and stand up to the heat.
        • #5
          Bruce,
          Just be sure to clean off all the oil first, RTV doesn't stick to oil!
          • #6
            Wine cork
            I got a wine cork at home and some silicone may even have a bit of wine left, will give that a try, thanks Ken and TC.
            Bruce
            78XS1100
            Bruce Doucette
            • #7
              Just remember - if you're going to 'harvest' a cork for doing this, you don't want to wind the corkscrew all the way through the cork. Come to think of it, you wouldn't want to do that anyways, unless you like floaty bits in your wine.
              IIRC, the time I tried this, I started with the cork from a bottle of champagne - no need to worry about the corkscrew. Keep this in mind if you're currently a bit low on brownie points with SWMBO.....
              • #8
                Just the sillicone
                Just the sillicone is all that was needed to stop the weeping of oil!
                Hey Ken, what do you call a basement full of blonds?
                Bruce
                Bruce Doucette
                • #9
                  Mine fell out too - I turned one from alloy yesterday and tapped it with a bit of studlock on it for security. The hole is 14mm and has a slight taper.
                  • #10
                    ... a whine celler... (isn't google wonderful..)
                    • #11
                      google
                      On there at work whenever time permits Ken..........
                      Typed in "motorcycle crash "just the other day, some of the pics that came up were awefull but grim reminders to try your best to ride safe...
                      Later
                      Bruce
                      Bruce Doucette
                      • #12
                        Lost one on a trip once. I now have a piece of wire bent across it, held to the snout by a small hose clamp.
                        • #13
                          I used a little bit of JB weld and a modified brass plug that was hollowed out on one side.
                          S.R.Czekus
                          1-big XS patch
                          1-small XS/XJ patch
                          1-XS/XJ owners pin.
                          Just do it !!!!!
