Hands-on?
  • Jerry
    XS & TRUE XJ GURU
    • 3023
    • Elma, IA.
    Hands-on?
    While out riding this last weekend, I started paying more attention how much time I spent riding with only one hand on the bars. Sometimes I use only the right hand, giving the left a break, but often flip on the throttle lock and use the left hand, giving the right a break. On some stretches I ride with both hands off the bars. Only time I really use both hands is getting out of town, going through twisties, passing another vehicle, or getting up to cruising speeds.
    So my question is....is this somewhat common? I'm talking about miles traveled, not hours/minutes of riding.
    If I had to put stats to it, I suspect I only use 2 hands 15 percent of the time, rest is probably 82 percent 1-handed, 3 percent no-handed. Varies a bit based on route, my commute is mostly interstate, so percentage of 1-hand or no-hand is higher than "recreational" riding, which tends to be more twisties and 2-hand riding, but over-all I don't travel a lot of miles with both hands on the bars.
    Jerry Fields
    '82 XJ 'Sojourn'
    '06 Concours
    My Galleries Page.
    My Blog Page.
  • Dragonrider
    • 1219
    • Garland, Texas
    Commuting in town, I'm almost always two handed (I live in a wicked town for commuting...think pinball...with guns).
    On long trips, I frequently have one or both hands off the bars. I've got electronic cruise, and my favorite super-slab riding position is: feet on the highway pegs, leaning back on the backrest, with my hands in my lap. I've gone more than 60 miles like that, never touching the handlebars.
    So...out of town...not burning up twisties...I'd say 80% of the time I have one or both hands off the bars.
    CUAgain,
    Daniel Meyer
    • Parr8hed
      • Aug 2003
      • 444
      • Southern Indiana
      even no hands now and then!!!!
      I am one handed alot, only right hand though. I don't have a throttle lock.
      Travis Miller
      1978 E
      • DeanR
        • Jan 2005
        • 1493
        • Finger Lakes NY
        I would appeciate some info on "throttle locks". How do they work, what to look for and where to find. Are they safe? Apparantly on new bikes it's some electronic configuration.
        80 SG
        81 SH in parts
        99 ST1100
        91 ST1100
        • Dragonrider
          • 1219
          • Garland, Texas
          Throttle locks are just a "flip" lever or cam lock that holds your throttle where you set it. They can be added to any bike and cost between $25 and $100 (some are chrome and fancy). They are safe if installed correctly...they just hold the throttle, you can easily overcome it and alter the setting. You can get them anywhere you get motorcycle parts.
          The disadvantage to these is that the bike will markedly speed up going downhill and slow down going up hill.
          Then there's electronic cruise control. Like a car, you push a button and it holds your speed at that point, adjusting the throttle as needed to keep the speed constant. You disengage by applying either brake, pulling in the clutch, or pushing the "off" button. Audiovox makes a "universal cruise control" for cars that many (including me) have put on motorcycles. It costs about $100.
          There's a pretty good page about this here:
          http://www.angelfire.com/il/sproulpage/page13.html
          CUAgain,
          Daniel Meyer
          • DeanR
            • Jan 2005
            • 1493
            • Finger Lakes NY
            Thanks for the info Daniel. I've checked a couple dealers and they had no throttle locks and didn't seem to know much about them. Just thinking it would be nice to sometimes give that right hand a break.
            I have a copy of your first book coming any day now!!
            80 SG
            81 SH in parts
            99 ST1100
            91 ST1100
            • Jerry
              XS & TRUE XJ GURU
              • 3023
              • Elma, IA.
              Have had a throttle lock on my XJ for 5 years now. Basically, they are an adjustable clamp, lever operated. Flip the lever down and the clamp holds the plastic that runs under the right handgrip in place, which effectively hold the throttle at that setting. The clamp force is adjustable, and I have mine set so I can still twist the throttle without much effort if I have to. Flip the lever up and the clamp releases completely.
              The lever/clamp fits between the left end of the grip and the handlebar. I had to slide my grip to the right about 1/2 inch to allow the lock to fit. There is a "U" shape in the throttle lock bracket that fits around the throttle cable fitting; this keeps the clamp in place when you are flipping the lever up and down. When you look for a lock you will see them advertised for single or dual throttle cables, this referes only to the bracket design. Get a single-cable set-up and you should be OK.
              Given the limitations of up and down hill riding, you will still be surprised at how often the lock works well. Giving your right hand a break for even a few miles at a time is very welcome on long trips, and I've run stretches of 60 - 80 miles or more with the lock on. If you plan any long runs, a throttle lock makes life easier. Plus you get to ride using only your left hand, or using no hands at all! You get some very interesting responses by waving both hands....
              Jerry Fields
              '82 XJ 'Sojourn'
              '06 Concours
              My Galleries Page.
              My Blog Page.
                I have had a throttle lock on my bike since I bought it over 13 years ago. I transferred it from my xs750SF .I used to ride for miles with no hands when the conditions allow, and with just one hand a lot. I can't imagine riding with out it now.
                • DeanR
                  • Jan 2005
                  • 1493
                  • Finger Lakes NY
                  Thanks guys. Now I just have to find one!
                  80 SG
                  81 SH in parts
                  99 ST1100
                  91 ST1100
                    • 7765
                    laxdad
                    try this link:
                    They have almost everything you need. I use them, but then I just ride down there at lunch!
                    Ray
                    • Materi
                      • Jun 2004
                      • 159
                      • Upton, WY
                      I live not too far from Sturgis, SD and see a lot of motorcycle traffic this time of year. I was on the interstate between Sundance, WY and Spearfish, SD (about 40 miles from Sturgis) in my pickup when I got PASSED by a guy on a Hardley who was leaning back against a sissy bar with his arms crossed behind his head and his feet crossed and resting on his handle bars. I kid you ney. He was in the middle of a group of about 25 or so other bikes. I immediately kicked the cruise off and slowed down...because a) I didn't want to distract him and have him plow me or somone else, and b) I didn't want to witness an Indian Larry type event right before my eyes. He rode that way until they were out of sight. I was doing about 75 so they had to be doing at least 80. What a nut. I mean he actually looked kind of cool and all, but man...y'know?
                      They Call Me the Breeze
                      '79 SF
                      • sixtysix
                        No XS but XSive as can be!
                        • 1958
                        • Central New York State
                        Jerry,
                        I am similar to you, I rarely use both hands unless I am braking hard, cornering hard, or accelerating hard enough to require it (read front wheel in the air). OK that may be most all the time but I really do ride with 1 or none most of the time.
                        Gary Granger
