Hard to get with the BAND.....saw!
Hey folks,
Okay, a short while back I got a second band saw blade from Little Machine Shop, was 6teeth per inch, vs. my oem 14T/inch blade. The coarser blade was recommended for cutting my 5.25" diameter Aluminum log slices faster, and it worked.
However, after cutting about 5 or so slices, the blade broke!
It did not separate at the weld, but about an inch or so close to it! Was a clean fracture, like a stress fracture that finally snapped!
So.....I ordered 2 more, only $12.95 ea. Put the new one on, and after only 5 slices, it broke!!!
I then put the 3rd one on, and finished cutting up that log, now have about 9 1.25" thick slices!! But I can't figure out WHY the blades are breaking?!
I've got the tension set just so that the blade is taught, but I can still move it a good 1/2" or so sideways at the long section between the large rollers on the slack=non cutting side! It's not getting HOT at all. The teeth are still razor sharp! I'm not sitting there pushing down on the blade/handle, just letting GRAVITY gently push the assembly down onto and into the workpiece!
They do sell another blade that is over twice the price, Powerband Matrix II, same teeth set. It's described as a BI-metal blade, a steel cuttng edge welded to an alloy steel back!? I guess you get what you pay for!?
I tried rewelding the broken one back together, but my MIG wire feeder was TOO HOT for it, just melted it!
I might be able to find a shop that can weld bandsaws!?!?
Hey folks,
Starrett Premium Hard Back BandSaw blade 64-1/2" x 1/2" x 0.025" thick. The 6S blade is for cutting sections over 1" thick. These blades fit the popular 4x6 bandsaw sold by Grizzly, Harbor Freight, etc..
Applications are light to medium vert. and horiz. machines, tool room and maintanence, low alloy, non-ferrous metals. Economical production cutting, increased tensile strength. More accurate and straighter cuts. Improved Blade rigidity for increased cutting rates.
I might be able to find a shop that can weld bandsaws!?!?T.C.
Just wanted to tell about their good service!!
