fuel cap
  • raider
    • 38
    • warr acres,ok
    fuel cap
    i have run into a slight problem and kinda wondering if anyone might know of a way to fix this so i can ride again!!!
    the problem is i can't get my fuel cap too unlock!! the key goes in and the tumbler turns but it does not engage or unlock the cap....
    now,is thing spring loaded?? i've tried cleaning it in case it was gunked up but that didn't seem to work so i'm thinking something in that mechanism might have broken.....
    if anyone can tell me how its supposed to work and unlock maybe i can figure this out!!!!!
    thank you much guys!
    81 xs1100sh......."the black-*itch"
    NOT ALL MEN ARE ANNOYING.......
    SOME ARE DEAD
  • 81xsproject
    • 3185
    • Fortuna, CA
    If I was home, I'd go check out my cap for ya, but alas I am no where near my beloved xs. Sorry.
    '81 XS1100 SH
    Sep. 12th 2015
    RIP
    • Targetman
      • Feb 2003
      • 130
      • Oshawa Ontario Canada
      You are pressing the cap down when you turn the key?
      I'm not trying to be smart. When I lost my keys and went to a locksmith, he made a new key and tried it and it wouldn't unlock for him either. Until I asked him if he was pressing down.
      Then it opened like buttah.
      1979 xs1100sf
      1972 cb500 four
      • raider
        • 38
        • warr acres,ok
        yeah i press down,lol....i've refilled enough to know...no offense taken there
        SOME ARE DEAD
          Raider,
          You're in luck, with a Special, just get a piece of stiff metal that you can have slightly bent, and use it to grab the spring loaded latch from under the cap, and then pry it away from the lip, again, pushing down slightly on the cap, and you should be able to get it open, then you can unscrew it and take it apart, repair or replace it!
          • raider
            • 38
            • warr acres,ok
            thank you very much for the advice...i' will try it as soon as i can manage to get away from this workplace!!!!!
            SOME ARE DEAD
