I give! *&^%%$# fuel line question!
  • jazzrat2000
    • Jan 2005
    • 298
    • Delray Beach FL
    OK, I give... I had to unhook the rubber fuel lines to take off the tank to do the valve shims with my friend... and several of them, being old, broke... decided to replace the relly short ones, and I went to autozone, got what looked like the right vacuum hose, and put it on... seemed a little looser than the old, but I figured it wasn't as brittle, maybe... after one ride, the tubes started to slip off, leading to a nice gas spill in my back yard... aaugh! so, I went to the local bike shop and got some smaller tubing, it was a bear to put on, but I figured I am set to go! After two weeks of rain I finally got (I thought) a chance to take a ride today... started to put gas in, and lo and behold all the new tubes had split, and another nice gas spill... so, now I am doing what I should have done in the first place, ask the experts! What kind of &^$%% tubing is the right kind, and where do I get it????
    Dr. Tim Walters
    Florida Atlantic University
    The Rats
    Full Flight Foundation, Inc.
    "just put the trumpet down and slowly back away..."
    "owned by a 79 XS1100 Special"
  • Czekus21
    • 1069
    • Keosauqua (Southeast) Iowa
    I went to Napa and spent a little extra on a marine type see through fuel line. It was about 12 buck for the 4 feet that I bought. I bought yellow, but blue, clear and red are available. The Napa I bought from only had the yellow in stock Looks like it wouldn't stand up to fuel but evedentlly that's what they're made for.
    S.R.Czekus
    1-big XS patch
    1-small XS/XJ patch
    1-XS/XJ owners pin.
    Just do it !!!!!
    • gerkenbruce
      • 392
      • Upstate NY
      BEEN THERE DONE THAT
      I like the clear nepream line,s new 1/4 hose clamps is the trick
      XSivly
      Bruce
      Bruce Gerken
      '79 XS1100SF
      "The Black"
      '2009 BMW k1300GT'
      The Red Sled.
      St.Augustine (354-430 AD) wrote,"The world is a book and those who do not travel read only a page . Well motorcycles turn the book of the world into a page turner. That is often impossible to put down.
      • jazzrat2000
        • Jan 2005
        • 298
        • Delray Beach FL
        I will take both pieces of advice! Thanks!
        Dr. Tim Walters
        The Rats
        • Artic_rider
          • Apr 2005
          • 130
          • Grande Prairie, AB
          Specs for the hose are 1/4 ID (inner Di) with a 3/8 OD (Outer Di)
          80' Xs eleven special "The Tank"
          • planedick
            • Mar 2005
            • 2068
            • Yorba Linda, California
            Gas leak?
            I'm sitting here wondering why you left the gas tank valve on prime. If you turn it to either of the two other positions no gas will come out without engine vacuum.
            Drilled airbox
            Tkat fork brace
            Hardly mufflers
            late model carbs
            Newer style fuses
            Oil pressure guage
            Custom security system
            Stainless braid brake lines
            • jazzrat2000
              • Jan 2005
              • 298
              • Delray Beach FL
              I am not known for my intelligence! the petcock was on the "on" position, I just leave it there usually and don't think about it. I guess the gas came out because the line was broken?
              Dr. Tim Walters
              The Rats
              • jazzrat2000
                • Jan 2005
                • 298
                • Delray Beach FL
                Or perhaps the petcock is messed up?
                Dr. Tim Walters
                The Rats
                • LoHo
                  • Sep 2002
                  • 1341
                  • Fresno, CA
                  Hey Jazz, are you saying that gas came out of the small vacuum lines that connect the carbs to the the petcocks? That's not right...
                  The vacuum hook-up to the petcock is what is supposed to open it for gas flow. If gas leaks out when the engine is off, you have a petcock problem; if gas leaks out of the vacuum lines to the carbs, you have a big petcock problem!
                  • Czekus21
                    • 1069
                    I don't know if you have a petcock problem or not. But,, On your SF, you have on,off, pri, and res. On my SF, fuel will flow with the tank off of the bike in any position but off. Run lets fuel in from the top of the pick up tube, reserve bottom of the pick up tube, pri, constant from the bottom of the petcock, and off, self expainatory. Mabee mines wrong but it works with no problems, Has been that way since I've owned it and it will stay that way cause it works.
                    S.R.Czekus
                    1-big XS patch
                    1-small XS/XJ patch
                    1-XS/XJ owners pin.
                    Just do it !!!!!
                      Czekus is right. On a Special, fuel will flow from any position but 'OFF'. If it still flows in the off position, then the petcocks need a new valve inside. That is the rubber disc with the three holes in it. Sometimes you can turn the disc over and it will work.
