Over Polished aluminum
  • 2manybikes
    • 194
    • Meadows of Dan Va.
    Sometimes when I am cleaning assorted scooter parts, they get a lot shinier than I like. Usually this occurs when I try to remove scratches and such. One of my other hobbies is restoring antique American clocks. (Pre 1920) I can clean the crud off the brass parts, then clean them with lacquer thinner to remove the wax residue, and coat them with mayonnaise. I'm no scientist, but the chemies in the mayonnaise react with the brass, and "tarnish" it fairly evenly. Works like a charm. Just wondering if someone knows of something that will do the same thing to aluminum, other than time! Going over it with a Scotch Brite pad, would not be my idea of a productive solution.
    • 7941
    Look up a Por 15 product called Glisten PC. Get the aluminum shiny and clean. The it gets etched before the clear coat. It looked about perfect to me. My friend that did it was unhappy because it dulled his mirror finish.
    My XS650 Heritage has it on the forks. Remember to get a good look when you come back. It's been on there for about 15 years.
    • 2manybikes
      • 194
      Over polished aluminum
      Thanks! I will check into it. I will also look into whether it can be diluted, or perhaps exposed for less time. I seem to be a bit duller after soaking in Old No. 7, maybe I'll try that since there is always plenty on hand!
        • 7941
        Glisten PC is epoxy.
        • MPittma100
          • Aug 2011
          • 2359
          Acid
          There is an acid that cleans aluminum. Truckers mostly use it for fuel tanks, etc. I have some and have used it on aluminum transmission cases. Can't think of the name of it off hand, but it leaves a finish that is somewhat dull. Would have to try it on a test piece to see if it is what you are after. Will find it in my shop and report back the name of it.
          1981 XS1100H Venturer
          K&N Air Filter
          ACCT
          Custom Paint by Deitz
          Geezer Rectifier/Regulator
          Stebel Nautilus Horn
          EBC Front Rotors
          Limie Accent Moves On In 2015
          Mike
            Hey Mike,
            When I read his last post about using Old #7, I checked it out, and sure enough, whiskey is fairly acidic, ph around 3-4, but your stuff might be cheaper??
            Years ago I was surprised to learn that ALKALI will also dissolve aluminum, so folks need to be careful with strong soaps also!
            • 2manybikes
              • 194
              Mike, Thanks for your input. Hope your shop is in better shape than mine is in!
              T.C. At 48 dollars a bottle, I sure hope so!
                • 7941
                I recommend over polished aluminum. It looks great!
