air fork balancing line
  • dpotter58
    • Aug 2004
    • 1866
    • Southern Maryland
    Used to have one on a bike. I want a new one for this one. I cant find them anymore. The one I had previous was from Progressive but it's discontinued.
    I have been Googling but no luck.
    Anyone have a source?
    1980 LG
    1981 LH
  • MPittma100
    • Aug 2011
    • 2359
    Fork Balancing
    Pick one.
    http://www.ebay.com/sch/sis.html?_nk...RK+BALANCE+KIT
    1981 XS1100H Venturer
    K&N Air Filter
    ACCT
    Custom Paint by Deitz
    Geezer Rectifier/Regulator
    Stebel Nautilus Horn
    EBC Front Rotors
    Limie Accent Moves On In 2015
    Mike
    • dpotter58
      • Aug 2004
      • 1866
      • Southern Maryland
      I'm not seeing anything there that looks appropriate Mike.
      This is what I used to have.
      https://www.amazon.com/PROGRESSIVE-S...ges/B000GTWMQU
      1980 LG
      1981 LH
        • 1259
        • Peachtree City, Georgia.
        Looking also....
        I cant find them anymore. ....Anyone have a source?
        dpotter,
        Good Luck finding one! I've been looking for more than a year and can't find one either. One of my XS11's came with one of these.....I assume this is what you are looking for also?
        These were extremely popular back in the 80's. They were more popular with the Motocross bikes but I've used them on both.
        Although the improvement is "Minor" at best, I do believe this device has improved the stock front end performance. If nothing else, it's a heck of a lot easier to verify and modify pressure.
        This is the only "Comparable" item I've found anywhere:
        I believe it is possible to fabricate one of these with commonly available parts from McMaster-Carr. That's my plan..... just haven't had the time to do it....
        Sincerely,
        1982 - CBX1000 - Honda
          • 9981
          He hasn't been on here since DragonTamer was killed but Mindwebs used to build them.
          Bigfoot has one he built.
          • dpotter58
            • Aug 2004
            • 1866
            • Southern Maryland
            what you talking about Wllis?
            1980 LG
            1981 LH
            • Bigfoot
              XS-XJ GURU
              • Sep 2005
              • 1422
              • Kansas City, Missouri
              A few years back DragonTamer and Mindwebs hooked me up with a neat setup for doing exactly what you are wanting to do. It was two hoses with fittings that screwed onto the valve stem of the fork, from there into either end of a T fitting with another valve stem on it. They are heavy duty hoses, I think I recall them saying they got the hoses from a truck supply place. I will try and find a picture of it.
              Harry
              '79 Standard
              '82 XJ1100
              '84 FJ1100
              Acta Non Verba
              • Bigfoot
                XS-XJ GURU
                • Sep 2005
                • 1422
                Here ya go
                Harry
                '79 Standard
                '82 XJ1100
                '84 FJ1100
                Acta Non Verba
                  • 9981
                  Mindwebs. I know what I was talking about and that's all that really matters.
                    • 6765
                    I too have been trying to help Kurt find the fittings he posted pics of and have come up blank...I have alot of dirt bike friends and none of them have ever seen the type of crossover that Kurt is looking for...the best suggestion was to lok into Mcmaster Carr...but thats a needle in a haystack...
                    2005 Honda SilverWing 600
                    2018 Honda PC-Xpress 150
                      Do you have to use XJ forks to be able to use the balance line between them?
                        • 9981
                        XJ forks are designed as such that they have the ability to balance themselves. Remember the grooves and O-rings in the tops of your tubes when we resealed them?
                          Yeah, I know the XJ tubes.. just wasn't sure about the others.
                            • 9981
                            Nope. Separate valves on each tube. That's the reason for this setup, like Harry has.
                              • 735
                              My 78E came with one on it:
                              The only markings I can find on it are the letters APMC
                              if that helps.
