trailer axle alignment
  • Blank Slate
    • Nov 2013
    • 393
    • Ottawa, Ontario, Canada
    Hello folks
    I had a trailer axle snap off while hauling some dirt. I bought a new axle, leaf springs, tires, all the bits, but the axle has these alignment spacers that have me stumped. One of them aligns with the leaf spring while the other is off by 3 inches. Will the trailer be ok with just one of these spacers aligning? I dont see what could be the harm. What do you guys say?
    Frame: 79 XS1100S
    Engine: 81 XS1100S
    Carbs: 78-79 BS34
    Gf bike: 78 XS650S
    Carbs: 70-79 BS38
    • 9981
    Turn the axle 90º so they will lay horizontally on the springs, center your axle and run one u-bolt on each side through the openings. It should work fine that way.
    • ViperRon
      • Feb 2011
      • 1062
      • Woodstock, VA
      Make sure to tighten the bolts attaching the bed to the leaf springs. That slack can cause wobble and increases stress on everything and if you put a load on may cause wiggle wobble and role and if you are going any speed you do not want that I have seen the result.
      Rodan
      1980 G Silverbird
      1198 Overbore kit
      Grizzly 660 ACCT
      Barnett Clutch Springs
      R1 Clutch Fiber Plates
      122.5 Main Jets
      ACCT Mod
      Mac 4-2 Flare Tips
      Antivibe Bar ends
      Rear trunk add-on
